key FOB all windows open
So I've been trying this for last few days and not working for me. I press unlock once on the FOB and then quickly a second time but stay on the button and it's not working. When I go through the MID in the section of door locks/windows when I go into that menu I see no windows option just locks.
https://acurazine.com/forums/second-...te-key-828863/
Should work . Have you tried replacing fob battery
you do it wrong, the correct way is press the unlock 3 times and hold the unlock button on the 3rd time.
Are all the windows going down from the master switch? It's possible you need to do a window reset on one/multiple of the 4 windows. I know the feature gets disabled if a window isn't reset.
Why isn't there a drop down for me on the MID where it says door and windows? I only see lock options.
The feature gets disabled from the fob if one of the windows isn't reset/isn't working from the master switch in the door. The way to check that is :Is one of the windows not going down from the master switch? If one of them isn't, the feature won't work from the fob. Only reason I know is because that happened to me.
Don't know what else to try. The proper sequence is fob unlock 1, then wait about 1 full second, then fob unlock again and keep holding it down. How about your spare key fob? Does it respond from that? And you're correct, there is no setting in the MID to control this behavior.
