Just picked up an 05' Few Questions- Specifically Speakers Crackling
Old 04-24-2012, 10:08 AM
  #41
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
In the service manual, there is a procedure for checking sound quality with these solutions. I assume the order is important.
Originally Posted by Audio System, RL Service Manual
If the sound quality is not comparable, check these items in order.
-Loose or improperly installed speakers or other hardware that may create interference
from the vibrations generated by the speakers
-Poor power or ground to the stereo amplifier
-Damaged speaker(s)
-Faulty amplifier
-Faulty audio unit
And Another interesting one:
ELECTRICAL NOISE TEST
Do this test to check for electrical noise being induced into the audio system.
1. Insert the audio diagnostic CD (T/N 07AAZ-SDBA100) into the audio unit.
2. Play track No. 4 (digital zero) at a normal, or slightly higher than normal, volume level.
3. Operate any electrical device that may create electrical noise in the audio system, including starting
the engine.
4. Play track No. 5 (near digital zero) at a normal, or slightly higher than normal, volume level.
5. Operate any electrical device that may create electrical noise in the audio system, including starting
the engine.
6. Play track No. 6 (SNR) at a normal, or slightly higher than normal, volume level.
7. Operate any electrical device that may create electrical noise in the audio system, including starting the engine.
NOTE: Before beginning the following tests, write down the client's bass, treble,
fader and balance settings, then set them to their center positions for the
testing.
NOTE: Electrical noise may be caused by outside sources that cannot be handled
by the audio system. Make sure you remove any cell phones and/or turn off
any aftermarket devices before beginning this test.
- If no abnormal noise is heard, go to the INDIVIDUAL SPEAKER TEST .
- If the noise is present only during the SNR track, replace the audio unit.
- If the noise is heard during the digital zero or near digital zero track, check for:
- Poor ground at the audio unit, amplifier, engine, or battery cable
- Pinched or shorted speaker or amplifier wire
- Faulty amplifier
- Faulty audio unit
- Other faulty components causing excessive electrical noise (ignition coils, alternator,
door lock actuators, etc.
). Disconnect any suspect components, and then replay the tracks
that were originally noisy. If the noise is gone, check the component's circuit and the
component.
Old 04-24-2012, 11:18 AM
  #42
HEAVY_RL's Avatar
Received 1,041 Likes on 846 Posts
Thats solid troubleshooting right there.
Old 04-24-2012, 05:09 PM
  #43
Tizodm80's Avatar
So it's not the Head Unit.
I had some offsite training today so I looked online and found a Head about 20min from my training. Picked it up and installed it about 10 minutes ago. Same exact symptoms.
I did try your advise oo7, however I couldn't locate a Test CD nor Honda or Acura would just let me throw theirs in my deck and play the 3 tracks. I had to setup an Appt.
So the limb I went out on with the deck broke, however I can return it (made sure) and will get an amp I suppose. I'll check the ground connection tomorrow perhaps once I find where the stupid thing is.
Thanks,
Todd
Old 04-24-2012, 09:24 PM
  #44
oo7spy's Avatar
I didn't expect you to get the CD. I was more pointing out the solutions since you already know there is an issue.
Old 07-02-2012, 11:41 AM
  #45
Tizodm80's Avatar
Hey guys, In case anyone has the same/ similar problem...I changed the Amp today with a used one and problem SOLVED!!
oo7spy (07-02-2012)
Old 07-02-2012, 03:09 PM
  #46
oo7spy's Avatar
Thanks for completing the thread.
Old 07-02-2012, 07:43 PM
  #47
Tizodm80's Avatar
Thanks for your help along the way Spy. BTW, should anyone feel they need the audio diag CD, PM me.
SinCityTLX
20
10-19-2015 11:23 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
rboller
09-23-2015 02:49 PM
Quick Reply: Just picked up an 05' Few Questions- Specifically Speakers Crackling
