Intermittent chime with Oil Icon lighting up...
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
I have been getting an intermittent chime with the oil light illuminating for a split second, then nothing happens and everything seems fine. I had the oil changed at the dealer on Friday morning, btw.
It usually happens right after start up, or when I have brought the car to a stop and only once in a while...
Any ideas?
TIA,
TXTENOR
Any ideas?
TIA,
TXTENOR
Any ideas?
TIA,
TXTENOR
Any ideas?
TIA,
TXTENOR
I echo the other post and Take back to the dealer to have them correct this!
Tom
Well, I finally have the diagnosis. It is a faulty oil pump and/or sensor. The tech said it was the first time he had seen one that failed. I asked if he thought it was the sensor or the pump itself, but he said that they would just replace the entire unit.
So, I should have her back tomorrow and I am really looking forward to it!
TXTENOR
TXTENOR
Originally Posted by kirbyflorida
How would that do it if his oil level is good????
LL
07 RL (non-tech)w/06 Nav
oil pressure sensors are positioned on the high pressure passage from the pump. Leaving a cap off, wont result in low pressure until most of you oil has soaked your engine compartment (may take 2k miles to leak enough out)
Probem solved! Evidently the oil pump was failing, or the sensor was. The oil pump was replaced, and the problem appears to be gone...Whew! Thank god for CPO..
TXTENOR
TXTENOR
mada51589
05-03-2022 08:54 PM
