Interior door panel removal
Old Jun 24, 2012 | 03:02 PM
vb9594's Avatar
All,
My '06 driver door speaker is blown and I am going to attempt a DIY replacement. I've searched the board to see if anyone had posted pics or info on how to do this but I was unable to come up with anything. Right now, my primary concern is getting the interior door panel off. If anyone has any advice, it would be much appreciated. Right now, the only obvious starting point I can see is a panel at the end of the interior door handle where I assume there are some screws that will get me started on removal...
Thanks!
Old Jun 24, 2012 | 07:29 PM
IanVS's Avatar
I attached a doc file with some directions and pictures that I used to replace the plastic trim ring at the bottom of my driver's handle. Should be what you need as well. It's one of the easier setups to remove that I've dealt with so far. Let me know if you can't see the attachment and I'll find another way to post.
File Type: zip
Old Jun 25, 2012 | 09:45 AM
vb9594's Avatar
Thanks!
Old Jun 26, 2012 | 12:00 PM
IanVS's Avatar
For those having trouble with a .doc, I attached a pdf version here: https://acurazine.com/forums/showpos...3&postcount=11. Should have just done that to begin with.
Feb 25, 2020 09:57 AM
handsom-hustla
Nov 13, 2015 05:04 PM
govtcheez
Oct 1, 2015 12:21 AM
CadiGTi
Sep 14, 2015 06:37 PM
