If I Could Change Just One Thing On My Rl It Would Be......
Although I think the RL is almost the perfect car...for me....there are a few things about it I would change.
The styling is a little too understated, but I park it on the streets of Newark, NJ so that might be a plus. The rear seats would be great if they folded down making rear cargo access better.
With only a few titles available in DVD-A format...it would be great if the audio system played the Super CD format.
That's about it....oh yeah...how about 50 miles per gallon.
I spoke to my delaer about folding seats and he told me the decision was made to keep the seats fixed because folding seats tend to let mor noise through and they wanted a quieter cabin. Not sure if it's the true reason but it's something...
LL
LL
2012 Cadillac CTS-V Coupe
LL
LL
Better seats.
Sit in a Mercedes and it's a big difference. Would be nice if they were ventilated/cooled and grippier for fast driving too.
#2 would be to make it smaller since I don't need all the space and #3 would be to remove the Bose noise cancellation feature because it scares me.
Tighten the turning circle, for goodness' sake. My G2 Legend was awesome in this regard.
The RL seats couldn't get much better IMHO. Maybe if they were cooled.
Rob144
Rob144
Trolling Canuckistan
Originally Posted by Qest
Better seats.
ANC scares me because it works by making noise to cancel noise. Maybe I'm paranoid, but I'm worried that it's damaging my hearing with loud noises I don't notice.
As long as the system is functioning perfectly, there's really no worries, but a small delay, or error could double the sound rather than cancel it. Hearing damage is cumulative, and permanent.
Bigger paddle shifters, less lean-bigger sway bars, 50 more hp, firmer brake peddle.
I would not worry about hearing loss with the ANC, you would need high volume for extended periods to get hearing loss.
This is minor....but I would rather see a big "push" buttons (like the TL) to increase or decrease the temperature setting. I don't like how one has to push up or down the tiny temperature control by 1 degree each time. I don't like the location of it either. Your arms is hanging without any support while trying to pin point the controls. I know, I know, use the voice command but sometimes you just want to be quiet esepcially when there are passengers with you. That's it...everything else is great!
I'd like to see the temperature control actually work, so I don't have to keep changing the setting!
ANC works be emitting inaudible frequencies to counteract audible frequencies. If the sound being blocked were doubled instead, it still would not be deafening (or damaging). You have more of a chance damaging your hearing listening to an ipod through headphones or even to your RL stereo at half volume.
Push button On and push the same button OFF for ignition. I now leave a note on the steering wheel when I give the car to a valet reminding them to verify by checking the dsahboard that the car is OFF. Too many dead batteries and few apologies from the valets (though LOTS of excuses!). I know that I only pay them a few bucks, but it shouldn't ake a PhD in logic to park the car and turn it off. Solved the "no key ring" problem by buying a small clear pouch with a key ring that holds the fob.
Ok two things not just one. First and foremost Laser cruise control or active cruise control without the rest of the package that you have to buy.
And why in the helll is there not Radio Data Display for FM. That extra chip could not have cost more than .25 cents. Even Fords haver RDS in their car radio's?
I agree with ventilated seating and a start/stop button. Just bear in mind that the European version of our car uses an actual key in the ignition, so the knob we have is probably a less-expensive way to implement keyless ignition in North America while omitting it in Europe.
Also, when I have the valet park the car, I leave the CD player on at a fairly high volume. That way, if the CD player is still running, then they know the car isn't completely off.
I think the seats are fine other than the lack of ventilation. My past car, a Lincoln LS V8 had this feature and I absolutely loved it in the humid summer months.
Puddle lights under the rearview mirrors for the approach to the car at night would be nice.
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
Puddle lights under the rearview mirrors for the approach to the car at night would be nice.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
2. Put a turbo in it....no V8 envy at all.
3. Better exhaust pipes.
4. Better looking/cheaper spoilers/aero package...
JB
Thanks!
No problem. The note on the steering wheel is a good idea, but I would worry about valets who have less than ideal English-reading skills.
05 slate grey e500 AMG sp
Sirius & Audio system play regular DVD's like infiniti so you woud not have to rip them & convert to dvd-a to listen to concert dvds
1. Better OEM rims
2. The interior trim of the driver and passenger doors seem to ride a little bit higher than the the window.
3. Better Nav screen in bright light situations
4. Thicker leather trim
It's "inaudiable" because the energy that's being put into the cabin by the speakers cancels out the sound energy leaking into the cabin -- because it's 180 degrees out of phase. If you were to isolate what the ANC system is playing without the road noise... it'd sound just like road noise.
But you need not worry about losing your hearing, because (a) it's less sound energy than the road noise, and that's certainly not enough to deafen you, and (b) the cancelling sound waves means there's no sound pressure -- the sound energy is dissapated. All it does is make the air in the cabin infinitesimally warmer.
Don't let ignorance breed fear.
Oh yeah, my big changes -- make the real time traffic actually factor into the route guidance, make the iPod Link actually WORK and show me song and album info on the navi screen, and better OEM tires.
What tires would you suggest for OEM? I know I'll be looking at seperate summer and winter rubber, but I think most RL buyers will enjoy the no-season Michelins that come with the car.
I can't comment on performance, but as a company, Michelin would be my last choice. Few regional dealers carry Michelin, and they all agree that it's nearly impossible to get any kind of customer service satisfaction from Michelin. You can spend an entire day reading customer complaints on the web.
Choice of Pilot Sport or Pilot Sport A/S is included in the OEM A-Spec package for people who won't mind the increased noise and harshness. Though, I think the Pilot Sport and PS A/S is an older, possibly obsolete, design.
1 I was surprised after I purchased the car that the passenger front seat did not have up or down adjustments. I previously owned an Acura Legend and expected a "luxury" car would have this feature. Felt I was cheated!!!
2. The wheels should be sound insulated from the cabin so that you do not hear tire noise. Ruins the quietness of the cabin!
Alpha Geek
My suggestion? Dunlops...just about any Dunlop kicks Michelin's a$$
I actually like Michelin tires. I've owned Dulops, Perelli's, even Goodyears, over the years and I've always gone back to Michelin. I've never had a Michelin leave me stranded, come apart, wear prematurely, or explode. I can't say the same for the other brands.
06 RL Lakeshore Silver
three things:
1) Auto sensing windshield wippers. Heck my 04MDX had it, why doesn't the RL
2) 3 inches added for leg room for the back seats. For a car that has 194" length, the leg room in the back is rather tight. (from what I hear...LOL)
3) Auto closing trunk. Again, with all the tech on this car, why did they leave that out.
Originally Posted by Touge
Some more power would be nice, but I'm working on that
, just added the aem cai and next up is a pulley.
![Devil grin](https://acurazine.com/forums/images/smilies/devilgrin.gif)
AEM does not show a CAI application for the RL. Where did you get yours?
I actually like Michelin tires. I've owned Dulops, Perelli's, even Goodyears, over the years and I've always gone back to Michelin. I've never had a Michelin leave me stranded, come apart, wear prematurely, or explode. I can't say the same for the other brands. ![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
