Hood release problem
Old Nov 8, 2011 | 09:01 AM
XXBogey's Avatar
On my '06 Rl...Cannot get the under dash hood release to function. It moves, but it won't release. Any suggestions, other than seeing dealer?
Old Nov 8, 2011 | 09:09 AM
HEAVY_RL's Avatar
have you modded or changed anything before it happened.
Old Nov 8, 2011 | 09:25 AM
XXBogey's Avatar
No, just checked the oil over the week-end (at the 15% level)
Old Nov 8, 2011 | 09:40 AM
HEAVY_RL's Avatar
Just a thought, I've seen the hoods with gas shocks (not particularly RLs) get hung up... have you tried letting someone pull the release while you gently lift the hood to see if its frozen or hung?
If that doesn't work you could dry spraying a penetrating oil with a straw, like WD40 or PB blaster, to help the latch.
Old Nov 8, 2011 | 09:43 AM
oo7spy's Avatar
Do you feel tension when you pull or is it completely loose? The handle is mechanical in that it is just a wire pulling a tab. If it is loose, your wire has become disconnected. If you can feel a resistance, then your latch is stuck like Heavy is talking about.
Old Nov 8, 2011 | 10:02 AM
XXBogey's Avatar
It's loose..in that there is no tension on the handle.
Is there access to the latch outside of the dash release?
Old Nov 8, 2011 | 10:05 AM
HEAVY_RL's Avatar
I would still try to tug the hood.
If you cant help it pop, then the cable is likely not connected.
Old Nov 8, 2011 | 10:27 AM
oo7spy's Avatar
Take the under dash plastic off. You should be able to find the wire behind the latch. It likely hooks on to the handle. Unless it dis-attached from the other side. That would suck.
Old Nov 8, 2011 | 12:00 PM
oo7spy's Avatar
Try engaging VTEC. That seemed to fix tongr's brake light issue. I'm beginning to believe it is the cure all for the RL.
Old Nov 8, 2011 | 12:59 PM
HEAVY_RL's Avatar
hahahahaha, there it is.
Old Nov 10, 2011 | 04:11 PM
XXBogey's Avatar
Solution turned out to be rather simple. Took it to a local mechanic and he
checked out the cable. Found out it was stretched about .250" and added a spacer. Works fine and cost $50.00.
Old Nov 10, 2011 | 04:13 PM
HEAVY_RL's Avatar
Good deal... its hard to troubleshoot that from the interwebs.
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
VA2000TL
Oct 2, 2015 08:26 AM
BookemDanole
Sep 11, 2015 04:53 PM
Sep 4, 2015 08:03 AM
