Honda Transmission Fluid Exchange Machine
Old Feb 12, 2018 | 01:44 AM
nickelrw87's Avatar
Hi!
I just got a part replaced on the RL - AC fan motor - and they (the Honda dealership)reported back that the transmission fluid is dirty. Im at 92k and plan on driving a long distance within the year so id like to get a flush anyways. I was reading the 3x3 flush is best,but Honda offered thier service that includes a "machine" and some "cleaner". Here is what they wrote:
"Using the state of the art machine, one of our trained technicians will use a safe and effective cleaner to dissolve and suspend the varnish and gums in the transmission, valve body, torque converter, pan filter element, transmission lines, and transmission cooler. The technician will then flush the entire unit of all old fluid and suspended debris, and install new transmission fluid. "
Does anyone know if this machine is worth it? Should i go with this service or specifically request a 3x3? Any thoughts would be awesome
Old Feb 12, 2018 | 07:33 AM
horseshoez's Avatar
Latent car nut
Do not under any circumstances have the machine flush your transmission; instead, have a 3x3 fluid replacement done. Your transmission will thank you.
Old Feb 12, 2018 | 08:31 AM
Ron A's Avatar
Administrator
Originally Posted by nickelrw87
i just realized this is in wrong sub cat
Thread moved.
Old Feb 12, 2018 | 08:35 AM
horseshoez's Avatar
Latent car nut
I just checked one of my Honda Owner's Manuals and this is what it says regarding "flushing" the transmission:
To thoroughly flush the transmission, the technician should drain and refill it with Honda DW-1, then drive the vehicle for a short distance. Do this three times. Then drain and refill the transmission a final time.
Old Feb 13, 2018 | 12:44 AM
nickelrw87's Avatar
got it. I will not be letting them touch it with the machine. 3x3 it is! I may just try this myself
Old Feb 13, 2018 | 04:58 AM
Bostech's Avatar
What is proper procedure when you are doing 3x3 drain?
Old Feb 13, 2018 | 06:18 AM
horseshoez's Avatar
Latent car nut
Drain the transmission, refill with three quarts, drive a bit, repeat the procedure two more times.
Old Feb 14, 2018 | 04:50 PM
truonghthe's Avatar
in the RL its more like you will have to do it 5 times because each time only 2.5 quarts come out.
Old Feb 19, 2018 | 09:28 PM
HDNBenjamin's Avatar
i got 2.9-3 last time on ramps
idkjai
Aug 12, 2009 11:16 PM
msvara
2G CL Transmission Recall Q & A
Apr 1, 2006 09:45 AM
cl-baller201
Nov 19, 2004 10:28 AM
