Headlight sensitivity
Is there anyway to make the headlights come on sooner/in brighter conditions? For instance this morning it was really overcast (and early) and raining on the way to work and defintely a time when I would use the headlights since it was so dark out still. My headlights stayed in DRL mode as usual. It seems they only come on when it's actually pitch black night time. The only adjustment I've found was the light sensitivity setting and I have that at max, which by the way made no difference whatsoever in how it operates. Does anyone have this problem or know of other things to set to make them come on before it's completely dark out?
Originally Posted by spacklebucket
Turn the headlights on
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
I always keep the lights in auto. When the car thinks it's too light out for headlights it keeps the DRL's on, then "automatically" turns on the headlights (and the DRL's off) when it thinks it's dark enough. So yes, I am in auto mode. I know how to operate the car and what the settings mean, I'm not an idiot. It was a simple question, is there a way to adjust it and since I'm at work and not near my manual I thought I'd post the question. It sounds like there isn't so thanks anyway.
Yes. As part of your options to configure through the MID, I believe you can configure the sensitivity for the sensor. Look in the manual - I don't have the RL anymore to give you step by step instructions on how to do this.
Also, since this is a topic that isn't specific to the navi or anything else, I am moving it to the general forum for more exposure. ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
![Damn](https://acurazine.com/forums/images/smilies/damn.gif)
I was about to pose the same question as AcuraRLBlue. If the windshield is dirty in that area or the sensor is dusty, it may effect the function of the automatic lights. Sorry I can't help you with any specific sensor adjustment technique - I haven't got a clue if that is possible.
'05 Acura RL - CGP/Ebony
EDIT:
I've now read the rest of the thread (so far) and see that someone has already mentioned the MID settings. I believe it made a difference when I changed mine and (as I said) it could be a bit more sensitive but it's not too bad for me.
Originally Posted by AcuraRLBlue
Any chance that the sensor is blocked?
Coincidentally today I was thinking how I don't like the auto setting because it's too conservative for me. I'll admit I've hardly played with the sensitivity setting though.
Stingerbtry, what you could do is use some scotch tape and put that over the sensor. This should reduce the amount of light that comes through and turn on the light earlier. You may need several pieces. This is just an idea, I haven't done this myself but I don't see why it wouldn't be worth a try.
And a big -thank you- from me for wanting your lights on under those conditions. Too many idiots refuse to turn on their lights unless it's pitch black. Don't get me started on a rant here![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Let us know how it works out.
office monkey
Something must be wrong with your car's sensor or we have a diff perception of darkness. My RL lights come on before I think they should and I have the lights set to come on at the darkest light setting.
My lights always come on in the situation you describe with rain/overcast.
Ok, maybe I'm not setting it in the right config screen because I haven't seen anything that even mentions dark/darker/lighter or whatever. The only config I have adjusted is the light sensitivity setting which has something like max/medium/mid/low or something like that. Is this what you guys are referring to? Please tell me there is another adjustment on another menu somewhere that I've missed somehow.
Originally Posted by Treblig
That's the menu that I am talking about. I have mine set to "mid".
office monkey
yeah that's odd bro. Mine is set to mid and if I had driven it this morn the lights would have been on as it is overcast outside right now.
Maybe mine is funked up compared to others.
This morning it actually worked a little better then usual. The headlights stayed on almost the whole way to work up until the sun broke the horizon. As soon as I saw the first ray of sun the lights turned off. Maybe this is a perception issue but I prefer driving with my headlights on in any low light condition. I don't think that having your headlights on before the sun comes up is too much to ask. I actually would've liked them to stay on a little longer as it was still low visibility out even though the sun was coming up. Oh well I guess I just have to live with it.
Originally Posted by lflorack
Does the fact that the DRL's are on even when the headlights are off help at all?
The circuit needs a Schmidt Trigger ( http://hyperphysics.phy-astr.gsu.edu...c/schmitt.html ) which basically means that once on the light needs to brighten more before it turns off again. Same is true the other way. This prevents the lights from blinking. It could also have some amount of delay that says the lights can't change state more often than once every minute or so.
In any case, I've had my S4 for 6 years and used the HIDs whenever I felt like it. They're still intact. Car HIDs are a bit special because they can turn on much quicker than consumer HIDs like those used in dive lights for example. Not sure how they do it.
Mine Too!
AmplifiedDetails
09-24-2015 02:55 PM
