Headlight Bulb Question
Old Mar 22, 2015 | 09:43 AM
bb37's Avatar
12 months ago I had the headlamps bulbs on my 2005 RL replaced with Heliolite W0133-1610302 Headlight Bulbs , now the drivers side just stopped working.
The body shop that did the work didn't put back all the plastic back proper come to find out and now I had to cut away some of the plastic as it became damaged by the the tire.
My question could the missing plastic have effect on the lights, bulbs or ballasts or could really the bulb just went bad this soon?
Old Mar 22, 2015 | 10:25 AM
NathanJax's Avatar
The ballast is on the bottom of the headlight surround. The bulb is inside the headlight and not only should have a plastic cap on it, but the bulb has it's own surround (projector) that it's inside of. So chances of anything (moisture/dirt) making a bulb go bad are slim to none.
Old Mar 23, 2015 | 07:32 AM
HEAVY_RL's Avatar
considering your car was put together improperly and you cut away vs fixing it... anything is possible.
Old Mar 23, 2015 | 08:15 AM
oo7spy's Avatar
Shouldve dropped the bumper and removed the assembly.
Old Mar 24, 2015 | 11:57 AM
bb37's Avatar
HD Bulb Choice for 2005 RL
Since I had replaced the bulbs with Heliolite W0133-1610302 on my RL and they only lasted 13 months , any suggestions on better replacements ?
Old Mar 24, 2015 | 12:03 PM
oo7spy's Avatar
D2S from here are all good (OSRAM are the best): The Retrofit Source | Innovative Headlight Upgrades
These will do as well: http://www.amazon.com/s/ref=nb_sb_no...s=phillips+d2s
Old Mar 24, 2015 | 12:50 PM
HEAVY_RL's Avatar
I see what you did there... nice approach OP.
pplcrew
Jan 30, 2021 08:59 AM
tman570
Jun 11, 2019 07:56 AM
BoricuaTL
Apr 8, 2016 01:08 PM
acuraST
Sep 17, 2015 02:31 AM
datadr
Sep 12, 2015 09:12 PM
