Headlight
Headlight
2005 RL, 125K miles
Had my Driver Headlight replaced (for free) several years ago due to the flicker issue.
Now passenger side is going out off/on - much more than a flicker, i.e., it goes out for many minutes. Will come back on when starting car, but will go out after driving for a while. Wondering if this is more of an igniter issue than bulb. Is there any diagnostics they can run on the igniter?
My dealer experience was not good in the first replacement. He said there were no tests they could run on the bulb and wanted to observe the flicker before replacing bulb. Since the flicker was very random and often very long in between, I asked him if he was going to have a Tech "observe" my headlight for several hours to diagnose. That led to a very good exchange of words!
In any case, given life of bulb, I will probably replace that as well if it is the igniter.
They actually do have a tester now, according to the Acura ServiceNews, but my guess is that it is the bulb at this point. Let us know what the deal is. I recall that several had used Amazon as a source to get Sylvania D2S bulbs, something like 3 or 4 times less than what the dealer charges.
There are threads on how to change the bulb, passenger side is apparently easier than driver side IIRC.
BTW, what is the issue with the igniter? Does it have a limited service life as well?
Missing my
Here's the link with great info from.... Chas! LOL!
https://acurazine.com/forums/2g-rl-audio-bluetooth-electronics-navigation-90/05-rl-headlight-flicker-695557/
I think I may be in the same boat. I gunned the accelerator the other day and my passenger side light flickered pretty noticeably. As for the ballast/igniter, I don't know how reliable they are on the RL, but the CLs all had major problems with them because they were not sealed properly. I was always having issues with my headlights on that car. I don't know if it applies to the RL...
I am having the same problem with my passenger headlight. I brought it to the deal and supposedly had the ballast and headlight assembly replaced. It still flickers so I’m not sure that they actually did anything. They are required to fix the problem since I have just purchased the car and have been complaing about it since the day I bought it. If you find anythign out please let me know and I will do the same!
From past experience, I suspect most flicker issues are the bulb (and there were lots of threads on the issue). However, in my recent case, with light going completely out for several minutes, do not know if that could be bulb or ballast/igniter.
Will update once I talk to Dealer.
I have not taken it in to Dealer yet, but talked to SA on phone. I told him the problem was intermittent, but when it does go out it goes out for a long time. Fortunately or unfortunately it worked fine last night for almost an hour of driving.
He said they have no good way to test whether it is bulb, igniter, or control unit when bulb is working.
Dealer "discounted" costs:
Bulb = $199
Igniter = $217
Control unit = $201
Bulb = $199
Igniter = $217
Control unit = $201
You may be able to replicate the flickering when your car goes over a bump. At least that's what I told my Acura Service Manager (Jim Brown at Herb Connolly Acura in Framingham, MA), and he replaced my driver-side headlight on my 07 RL.
it does not appear bump related. It may flicker a few times, but then when it goes out, it is out for rest of the drive.
I'm using 2 ebay brand bulbs for the last 2 years at cost of less than $20 for both shipped. Not sure brand name bulbs will do much better. I am getting some flickering and random turns off now so I'm gonna see if it's the bulbs by replacing with oem. Never knows...
I've got the same problem with the driver side light. it flickers whenever the car is turning left (probably because the bulb turns with the car). not sure if its the bulb or something else, but the dealer "could not duplicate problem", and hence didn't do anything about it. Local auto shops run the light at $150. Are
amazon sold bulbs OEM or aftermarket ones?
thanks
thanks
the oem bulb I got are xenox brand or something. Technically there is no such thing as oem, it's whatever bulb they pick at the time. If you think it's the bulb, pay $20 on ebay and swap em out your self, if that fixes the issue, you're done. If it doesn't...you saved over $100 per light which would be made in germany and make absolutely no difference.
i should have kept the old/original bulbs so i could photograph and post. i'm quite certain they were sylvania bulbs. at the very least, ALL the numbers/print on the original bulbs matched EXACTLY the replacement sylvania bulbs i purchased on amazon for $53ea
You could both be correct.
Osram Sylvania Inc. is the North American operation of lighting manufacturer Osram GmbH, which is owned by Siemens AG. It was established in January 1993, with the acquisition of GTE’s Sylvania lighting division by Osram GmbH
AmplifiedDetails
09-24-2015 02:55 PM
