Gas pedal is slightly hard to press
My gas pedal has recently been hard to press. Like its not that sensitive and It lags to get up to speed. Im a big DIY guy and this is my fisrt ever car. Ive done all the basic cleaning including my air filters and removing all my air intake systems and cleaning them with the proper cleaning supplies ive learned on here. But I just feel like my RL can do soo much more. Its a 06 RL wit only 119k. Hope someone can help
I'm confused on the symptoms of the issue. The pedal is hard to press like it takes more than expected force? Or you have to press the pedal farther than expected to get throttle response?
It takes more than expected force. Basically I can push it down 25% and it will sound like it's in first gear and the vehicle will be barely moving. Fuel injectors clogged or something wrong with gas pedal?
Have you tried manually shifting the car to see if it gets out of first gear? Based on the limited information, it almost sounds like An electronic issue with the gas pedal, which is drive by wire, is not sending a proper signal to the throttle? Could be a bad pedal? I would check to see if the car CAN get out of first (do so safely of course
I can drive it and shift from 1st to 3rd with no problem. It seems like it's in 1st gear until I get up to 30 -40 miles an hour. The 1st gear feel is there until 30-40 miles an hour. The vehicle sounds like it's in neutral when I am pressing the gas pedal...... naturally it's in drive the whole time.
What area of the car is that picture of?
There is an injector TSB for certain time periods of KB1 production, but I don't know that it applies. Do you have any lights on your dash or error messages elsewhere besides VSA 61?
![what](https://acurazine.com/forums/images/smilies/what.gif)
No and No.... it was on private property and I have a deductible that is high. Insurance will raise your rate for minor claims. I found a replacement headlight assembly locally.
The solenoid coil housing has snapped off. It can be fixed but will require some testing equipment to confirm proper operation after repair.
If you don't want to bother with all that then just get yourself a new clutch pressure control solenoid valve C, it is secured with four 10mm bolts. Easy install and no calibration necessary.
The following 3 users liked this post by CurrentDraw:
I pulled the codes and the following codes showed up: P1745, P1780, P0746 Pressure control solenoid "A" Performance/ Stuck Off and P0777 Pressure control solenoid "B" Stuck on. I am going to change the transmission fluid and replace the solenoids.
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
I would do a quick visual check on your DTC triggered solenoids A and B and if everything checks out then start by replacing C since you know it is broken and go from there. Those solenoids are not cheap and if you go out replacing them just because the scanner is throwing a DTC for it you may be spending money for no reason. Good luck.
The snapped portion of solenoid C houses the electrical coil winding which is continously monitored by PCM for shorts and open. Since the connector nor the housing is damaged, solenoid C is known "good" and electrically sound as far as the PCM is concerned. The PCM doesn't have the luxury of doing a visual check but we can, and it is clear from your pic that solenoid C is detached from its valve/pintle housing (bolted to the transmission).
alexpapas90
05-11-2016 10:17 AM
