Engine Explosion, totaled? *Pics Included*
Old 09-19-2016, 03:04 PM
Tyzing's Avatar
2006 Acura RL ASPEC rims - 130,000 miles
Hey guys - my car was running and I got out and it just cut off. Tried cranking it over and over with no luck. The next day I tried again and a loud explosion happened and the result was below. So nasty...can't say I've ever seen a gas engine do this before.
Is this worth repairing?
Old 09-19-2016, 03:26 PM
deepdezal's Avatar
seems like a big back fire.
IMO.. sure worth fixing up...perform a compression test and also confirm the TB is still on and has not jumped. if both check out, proceed to fix the issue. more than likely leaky fuel injectors..
Good luck.
The following 4 users liked this post by deepdezal:
oo7spy (09-19-2016), projektvertx (09-19-2016), RL09 (09-19-2016), Tyzing (09-19-2016)
Old 09-19-2016, 03:31 PM
Received 8,747 Likes on 6,748 Posts
not really the engine, just the intake manifold, should be fairly simple provide the rest of the engine is fine!
Tyzing (09-19-2016)
Old 09-19-2016, 03:34 PM
oo7spy's Avatar
Received 7,249 Likes on 4,859 Posts
That's the intake manifold being blown off, right? Is there damage to the underside? What in the world would cause that? If it is just a damaged intake manifold and you can pass compression, I agree with dezal. Otherwise, I have to think an engine swap would be easiest and cheapest.
Tyzing (09-19-2016)
Old 09-19-2016, 04:21 PM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
W.T.F.
Is timing ok? Pistons ok? Spark plugs ok? Head gasket ok? Head ok? Sensors ok?
Old 09-19-2016, 04:39 PM
projektvertx's Avatar
What in gods name happened here...
Old 09-19-2016, 04:49 PM
Jeff
Oh Sickest TL's Avatar
Are you sure its not because of your rims
Old 09-19-2016, 05:20 PM
Majofo's Avatar
Received 11,843 Likes on 8,574 Posts
No.. just no.
Unless you think intake manifolds spontaneously explode.
Old 09-19-2016, 05:23 PM
FkNo!TheyRdstroyinEvrting
RL09's Avatar
At least no one got hurt.
hope you manage to fix it.
Old 09-19-2016, 05:56 PM
Majofo's Avatar
OP you dun goofed.. that's one fucking epic intake backfire.
It's rare but not unheard of (punzine). You sure you didn't spray a whole can of carb cleaner down the throttle body before starting her?
It's possible that you had a stick injector, but not likely.
The cause is simple.. built up fumes, chain reaction with spark and boom.
The root of the issue will be more difficult to figure out. First spec all the injectors, then spec the intake valves. Spec the timing and check the egr valve.
Somewhere along those lines, unburnt spray was allowed to cycle back to the IM.. yada yada yada.. kaboom!
The intake manifold is an easy replacement. You should replace all the bolts and gaskets too. IM is usually the weakest point of the chain.
But that explosion is fucking glorious. I'd check everything. I'd be real interested in the valve and timing spec.
The following 4 users liked this post by Majofo:
RL09 (09-19-2016), thoiboi (09-20-2016), ttribe (09-20-2016), Tyzing (09-19-2016)
Old 09-19-2016, 05:59 PM
Majofo's Avatar
Also check plugs and coils..
Tyzing (09-19-2016)
Old 09-19-2016, 06:04 PM
RL09's Avatar
I don't think it had time to get to the belt and valves, pistons... Pressure went upwards. my guess is those are still good.
Tyzing (09-19-2016)
Old 09-19-2016, 06:23 PM
oo7spy's Avatar
First thing I thought was that he threw a rod, but those aren't under the IM. Obviously Joe is right about gas build up, but I don't get how.
Old 09-19-2016, 06:45 PM
JDMCRX's Avatar
Thats a big back fire ! dont crank it over once so ever !
Put the motor at TDC on the crank and check that your cam gears are all aligned first before doing anything else and report back !
Old 09-19-2016, 08:39 PM
teh CL's Avatar
Wow
Old 09-19-2016, 08:59 PM
thisaznboi88's Avatar
wow did you hit the nos button or something? Blew the welds off of the intake manifold
The following 5 users liked this post by thisaznboi88:
justnspace (09-20-2016), Majofo (09-19-2016), projektvertx (09-19-2016), SHUJeff281 (09-24-2016), thoiboi (09-20-2016)
Old 09-19-2016, 09:46 PM
^loll
Old 09-20-2016, 02:17 AM
RL_Coastin's Avatar
That looks insane, almost looks photoshopped! If everything else checks out okay, you should swap to a j37 intake manifold
Old 09-20-2016, 10:24 AM
Blues Legend's Avatar
Either that or your turbo BOV is stuck closed.
More likely, you flooded it trying to start it and the vapour settled there and ignited the next day.
Something wrong with your valves or ignition timing's a tad advanced.
It's bloody impressive, anyway.
Old 09-20-2016, 10:27 AM
i spy an SRI/CAI install
if you go to the dealer,$10 says they'll blame that
Old 09-20-2016, 11:47 AM
Jeff
The hondabond between the two halves is still intact
Old 09-20-2016, 11:55 AM
3.5 psi
gnuts's Avatar
that's crazy! how much is a replacement engine?
Old 09-20-2016, 11:57 AM
TacoBello's Avatar
Fairly cheap... If from the wreckers.
Old 09-20-2016, 12:47 PM
oo7spy's Avatar
You can do a used engine swap for ~$3K.
Old 09-20-2016, 12:57 PM
TacoBello's Avatar
I assume you're including labor in that price too, yes? I thought you can snap up a used engine for 1500ish...
Old 09-20-2016, 12:58 PM
Received 16,267 Likes on 11,974 Posts
way less!
i used Car-Part.com--Used Auto Parts Market to source my used engine. found one that was going for $650. when I got to the junk yard, dude had PLENTY of J32/J35's. he let me choose the one I THOUGHT was the best conditioned.
took the engine over to my mechanic and had him install it in a week for $650 and some change for fluid, etc.
~$1300 in total.
that is if you can get a mechanic to swap it for $650.
Old 09-20-2016, 01:00 PM
someone in the BM was selling a J35 block
i'd find the link but i'm too lazy
Old 09-20-2016, 01:04 PM
TacoBello's Avatar
Yeah these engines are a dime a dozen these days. There's nothing special about them either, so it's not like they are in high demand. I'm not surprised Spaceman grabbed his for well under 1000... I was thinking I could get one up here for 1500...
Old 09-20-2016, 01:08 PM
obviously; the lower the mileage the higher they are going to price the engine.
I Knew going in that these engines are bullet proof and wouldnt mind a 100k+ mile engine.
if I wanted one closer to the mileage on the body of the car, ~75k miles, It would have been in the $1000 price range
I couldnt Justify ~$1650+ on the swap. so, i settled for a higer mileaged engine.....which has been trouble free in the last year
TacoBello (09-20-2016)
Old 09-20-2016, 01:16 PM
TacoBello's Avatar
As far as mileage is concerned, I wouldn't be that worried either.. the J series can take a lot of abuse before showing any issues... if decently maintained, it's all good. I'd definitely do some easy maintenance while the engine was still out, rather than battle with it later. Replace the seals now, check the engine mounts now, etc...
Old 09-20-2016, 01:24 PM
^yeah, mechanic swapped everything over to new-used engine.
all of my aftermarket mounts, my aftermarket throttlebody, and my painted wrinkle red valve covers.
also swapped over the new timing belt and water pump i had just put on.
he did some extras too, that he didnt have too.
I had some ghetto washer-bolt method and he replaced it with the correct length bolt
Old 09-20-2016, 01:31 PM
Derek
SykVSyx's Avatar
I got my J35 and tranny for under $1000 at the time.
Mileage was decent on both, so, good deals can definately be found on car-part.com.
Old 09-20-2016, 01:41 PM
Jeff
taco, theres a JDM shop in Montreal that has boatloads of acura/honda motors/trannys for great prices.
When my tranny blows ill likely fork the cash over and go 6spd, hopefully thats not for a few years though lol
Old 09-20-2016, 01:46 PM
TacoBello's Avatar
Yeah, I looked at buying a Type R engine from them, many years ago.
Honestly, I'm not sure that 6mt swap is worth it. Plus there is a bunch of shit to wire up to make sure everything works as before... You'd be better off just buying a TL with a 6mt to begin with.
It's not that it can't be done, but there's a reason only a handful of guys have done it. And no one has done it (at least on AZ) in at least 2 years.
Old 09-20-2016, 01:53 PM
RL09's Avatar
What's a JDM shop?
Old 09-20-2016, 01:55 PM
Jeff
well if (when) the AT blows then I dont see an issue with doing a swap? Im certainly not going to go out and buy a whole other car when my car is in better shape than the majority of TL's out there
Old 09-20-2016, 01:56 PM
TacoBello's Avatar
Joo Dumb Moron shop. It's where you buy all your clothes.
Oh Sickest TL (09-20-2016)
Old 09-20-2016, 01:57 PM
Originally Posted by RL09
What's a JDM shop?
Japan Land domestic market
RL09 (09-20-2016)
Old 09-20-2016, 02:00 PM
TacoBello's Avatar
You're enabling him
Old 09-20-2016, 02:01 PM
You're enabling him
check what section we are in.
as much as a weirdo i think he is, still have to play by the rules or SPY gonna whoop my ass
The following 3 users liked this post by justnspace:
HEAVY_RL (09-29-2016), oo7spy (09-20-2016), projektvertx (09-20-2016)
Quick Reply: Engine Explosion, totaled? *Pics Included*
