Engine Air Intake Hose
Old Jan 22, 2013 | 07:49 PM
Professor's Avatar
Карты убийцы
On the 2005 RL, I'm I corrected that this is the tube running from the throttle body (top right of engine) into the air cleaner housing (in front of the battery)?
I had the oil changed at the dealer today, and they said the hose was torn and barely hanging on at the top and basically getting unfiltered air into the engine.
I get home, pop the hood and check. The tube running to the throttle body is solid; not tears or holes. Is there another hose on the underside of the air cleaner case?
Old Jan 22, 2013 | 08:29 PM
oo7spy's Avatar
The tube runs from the engine to the filter like you explain. It then proceeds past the filter housing through a resonator, under the battery, and then back up to a snorkel at the edge of the hood in front of the battery. If the hose between the engine and filter is intact, you are fine (assuming there isn't a crack at the very bottom that could draw water in a puddle).
Are you sure the bottom/back of the hose isn't compromised?
Old Jan 22, 2013 | 08:59 PM
Professor's Avatar
Карты убийцы
^ Thanks. I'll check from the resonator to the snorkel... but I'm positive the tube from the engine to the filter case is solid. I went on Delray Acura's parts site and the diagram of the air cleaner case only shows a tube going from the case to the throttle body.
Old Jan 22, 2013 | 09:51 PM
oo7spy's Avatar
I know it's there. If you have ever changed the driver's fog light, that's the tube that is a pain in the ass to get around.
drone619
Jan 26, 2016 07:09 PM
Kevin Sami
Sep 22, 2015 09:59 AM
Sep 14, 2015 10:09 PM
Mikehxbx
Sep 13, 2015 01:09 PM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
