ECU ?? reset
Old Oct 25, 2009 | 06:03 AM
jfprl's Avatar
ECU ?? reset
My son picked up a method to reset his ECU ( or throttle control) on his 08 TL Type S from the TL site which involves holding the gas pedal down for 30 seconds after a couple of other steps. He claims his car is more responsive after the procedure. I went to the TL site and read how many confirmed this procedure and the results. While a few said it made no difference. Any of you guys tried this on our RL or anything similar?
Old Oct 25, 2009 | 09:27 AM
Blazing GT's Avatar
just disconnect the battery for like 15 minutes and you are golden
Old Oct 25, 2009 | 11:32 AM
csmeance's Avatar
if you do this you will need to do the idle relearn procedure, window switch initialization, sunroof initialization, and you loose your memory seats and other settings.
Use the gas pedal method, it clears out the Drive By Wire memory so the way the car "adapts" to your driving style is erased so you are back to factory defaults and the learning stage.
Old Oct 25, 2009 | 02:22 PM
Chas2's Avatar
Do you have the exact procedure?
Old Oct 25, 2009 | 02:27 PM
Blazing GT's Avatar
i did the throttle reset method and i got no results
Old Oct 25, 2009 | 09:12 PM
jfprl's Avatar
From the TL site:
turn the key to the second position make sure everything is off like radio ac and so on... take it out put it back in and then again to the second position and press the gas pedal for like 30 seconds... i do it for a minute just to make sure. Then simply turn of take the key out put it in and turn the car on and there you go
im sure i put couple of extra steps that maybe are not needed but im just making sure i do it right
works everytime
brboy
Oct 5, 2015 11:34 AM
Skirmich
Oct 1, 2015 12:59 PM
malvothegreat
Sep 29, 2015 12:38 AM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
