easiest way to replace rear main seal
Old Oct 29, 2018 | 02:03 PM
fuzzysig's Avatar
anyone has any tips on replacing rear main seal on 2005 RL?
in the garage without lift
Old Oct 29, 2018 | 02:13 PM
no easy way.
Old Oct 29, 2018 | 02:47 PM
Midnight Mystery's Avatar
Null and proud of it
Ummm... Engine and tranny need to come apart...
Use jackstands, hoist, and drop subframe...
I believe it goes something like this...
Old Oct 29, 2018 | 03:58 PM
Ken1997TL's Avatar
How bad is the leak?
Old Oct 29, 2018 | 09:11 PM
DagMDX2011's Avatar
Use some Valvoline Maxlife oil and hopes it seals up.
Old Oct 29, 2018 | 09:55 PM
projektvertx's Avatar
That was my first thought.
Old Oct 30, 2018 | 07:22 PM
fuzzysig's Avatar
quart every 1000 miles
Old Oct 30, 2018 | 07:25 PM
GhostTL09's Avatar
damn that's alot of oil
Old Oct 30, 2018 | 07:46 PM
My Camry leaked that much with the valve cover and front main... Should've just left it, not use that ATP 205 Re-Seal...
BTW, hell no, don't use that, killed my engine...
Old Oct 31, 2018 | 12:21 AM
Replace your PCV valve. That usually alleviates seepage at the rear main seal.
Old Oct 31, 2018 | 12:28 PM
fuzzysig's Avatar
pcv valve is good. been replaced since I got the car
it needs to be replaced
Old Oct 31, 2018 | 12:52 PM
horseshoez's Avatar
Latent car nut
Well, you're either going to have to drop the subframe/tranny or yank the engine out the top.
Old Oct 31, 2018 | 09:09 PM
truonghthe's Avatar
There is no easy way, unfortunately the sub frame has to be drop and transmission has to be removed.
Dealer price is right around $2k and my Honda/Acura indi shop quoted at $1200. lucky for me switching to Mobil 1 high mileage stop the leak, but if it get worst I will get it replace along with refresh the front suspension.
Old Nov 3, 2018 | 03:10 PM
beekermartin's Avatar
The main seal in my 2005 RL started leaking. I was using regular Mobil 1 5w20 at the time. I switched to Mobil 1 High Mileage 5w20 when I noticed the leak had started. By the second oil change after switching the leak was completely gone. It was bone dry and has been ever since. YMMV of course but switching to a high mileage oil with seal conditioners fixed my main seal leak.
Old Nov 4, 2018 | 11:23 AM
fuzzysig's Avatar
I guess I could try that
Stimpy
Oct 2, 2008 11:43 AM
Allout
Feb 15, 2006 10:25 PM
DeezNutz
Sep 15, 2005 01:44 PM
Chemmech
Apr 17, 2005 11:07 AM
zeta
Jul 31, 2004 02:17 PM
