Drl Replacement
Old Mar 31, 2009 | 01:23 PM
gogogoldrl's Avatar
Drl Replacement
How difficult is it to replace the right side low beam (drl headlight)
Gordon
Old Mar 31, 2009 | 02:10 PM
Chas2's Avatar
Look in the manual. In the 06, it is P 372, It tells you how to change the DRL. You can do it yourself.
Old Mar 31, 2009 | 02:15 PM
Ballinger's Avatar
Your DRL's operate off the HIGH beam, and are an incandescent bulb. Your LOW beams are an HID. The high beams are pretty easy to swap out, although you've got to move the battery to get in there on the driver's side.
Old Mar 31, 2009 | 02:22 PM
BackinBlackTL's Avatar
i like it dark
are there any yellow replacements for the DRL's?
Old Mar 31, 2009 | 03:29 PM
Ballinger's Avatar
Sure, but yellow high beams are illegal in 49 states and several territories. Note that they'd only be "on" in the daytime, since as soon as you illuminate your low beams, the DRL's turn off.
Old Mar 31, 2009 | 04:13 PM
Treblig's Avatar
An easy DIY project.
Old Mar 31, 2009 | 06:37 PM
gogogoldrl's Avatar
Thanks for the pointers i"ll give it a shot.
niray9
Dec 8, 2015 07:34 PM
sockr1
Oct 1, 2015 01:31 AM
JnC
Sep 11, 2015 06:06 AM
spiel08
Sep 7, 2015 08:19 PM
Fadij
Sep 2, 2015 08:31 PM
