Drl Replacement
Your DRL's operate off the HIGH beam, and are an incandescent bulb. Your LOW beams are an HID. The high beams are pretty easy to swap out, although you've got to move the battery to get in there on the driver's side.
Sure, but yellow high beams are illegal in 49 states and several territories.
Note that they'd only be "on" in the daytime, since as soon as you illuminate your low beams, the DRL's turn off.
An easy DIY project.
sockr1
10-01-2015 01:31 AM
