Driver door won't open from inside
Old Oct 22, 2021 | 03:20 PM
MjAuto's Avatar
Odd thing happened today, I can't open the driver's side door from the inside. It will open from the outside. It will lock with both the fob and the inside lock button on the driver's door.
I took the panel off and can see the both wires for the lock and handle are attached and moving. But can't feel inside the door panel too well.
Does this mean the actuator is broken? If so, is it an easy replacement? And how?
Old Oct 24, 2021 | 10:17 PM
MjAuto's Avatar
No one has an idea what the issue is? Come on help a guy out
Old Oct 25, 2021 | 08:12 AM
Rogeroge's Avatar
Knowing this community, your not being ignored. We are sometimes shy about telling more than we know.
Old Oct 25, 2021 | 10:50 AM
Have you looked at the cable that attaches to the inner handle and see that it is moving freely? Is it then attached properly to the latch mechanism? It could be that the inner handle mechanism is broken, we need more information to properly diagnose
Old Oct 25, 2021 | 06:57 PM
MjAuto's Avatar
Yes, as stated earlier, the cables are attached to both the inside handles (lock and door opener) and both move freely. I can't see behind the door panel where those cables go
Old Oct 26, 2021 | 11:44 AM
Blues Legend's Avatar
I thought my actuator had gone, but the dealer said the cable had fallen off and attached it FoC.
Passenger door, which is your driver's door. Maybe they all do that, sir?
Old Oct 27, 2021 | 11:00 AM
theShaft's Avatar
Put your window down and open the door using the outside handle. This will get you out of the car.
Been there for the moment of PANIC when you cannot get out of the car... LOL I'm a big dude and crawling out over the console is the last thing I wanted to do in a busy parking lot.
There's a cheap little clip inside that tends to break on the RL. I had mentioned it to my dealer before it broke that it felt funny opening while in for service. They checked it and found no issue. Withing the week, it broke.
Return to the dealer for a free fix and a car wash. >
Old Nov 1, 2021 | 06:03 AM
MjAuto's Avatar
I took the car to the dealer Friday, yeah I have a broken wire - probably that clip. They temporarily got it working, but said it could fall off any time after 1 use or 20. They ordered the part and will have it this week.
Old Nov 5, 2021 | 11:47 AM
It's not so much Dukes of Hazzard, more reversed Lead Sled, where the exterior door handles are shaved & filled.
1. Restart engine.
2. Press window auto down.
3. Open door from outside and loudly curse twisted shoulder.
4. Alight.
5. Reassembly is the reverse of disassembly...
Chans
Aug 17, 2024 10:24 AM
UA6SPD619
Mar 6, 2021 09:23 PM
Acura_9771
Jul 2, 2017 12:34 PM
drjoe
Jan 12, 2015 04:12 PM
papo026
2G CL Problems & Fixes
May 19, 2009 09:00 PM
