Drive-By-Wire
Old Sep 25, 2005 | 03:09 PM
suj220's Avatar
SCMPredator
Question Drive-By-Wire
Does the new RL have drive by wire technology?
Old Sep 25, 2005 | 04:16 PM
static808's Avatar
Yes. It is mentioned on acura.com in the specs/details section.
Old Sep 25, 2005 | 04:50 PM
NFLblitze1's Avatar
Youse Gots Sacked
what is DRIVE BY WIRE tech?
Old Sep 25, 2005 | 08:18 PM
GIBSON6594's Avatar
My Garage
"In most cars, a mechanical cable connects the accelerator pedal to the throttle valve. The RL uses the all-electronic Drive-by-Wire Throttle System™, first developed for Honda Formula 1 racing engines. It senses accelerator pedal motion, then a computer weighs this data against vehicle speed and engine data in real time and opens the throttle accordingly. The pedal feel is more direct. Acceleration is smooth from rest, and immediate at normal cruising speeds, for quick passing. Because control is more precise, throttle response is quick and sporty. Exhaust emissions are reduced, and performance and fuel economy are improved. Drive-by-wire facilitates communication between the engine, the ABS and Vehicle Stability Assist (VSA®), enabling a more coordinated reaction by these systems when they are engaged. In the RL, throttle position and shifting are coordinated electronically, so the shift "feel" is more refined."
http://www.acura.com/models/model_pe...asp?module=rl#
Old Sep 26, 2005 | 08:23 AM
Rob L's Avatar
office monkey
I find cars with that drive by wire throttle stuff are much easier to keep at a constant speed.
Old Sep 26, 2005 | 08:29 AM
Rich in NC's Avatar
Unemployed or retired?
"By wire" control systems that aren't mechanically linked. Since everything but the throttle has direct mechanical links. It is more like throttle by wire.
RLX-Sport Hybrid
3G RLX (2013+)
Jan 14, 2015 11:47 PM
rb1
1G TSX Problems & Fixes
19
Nov 19, 2010 12:27 PM
Zoopa
May 11, 2007 03:10 PM
gavriil
Sep 16, 2004 03:38 PM
Zapata
Sep 25, 2002 01:51 PM
