Disable the auto-retract rear shade when in reverse
Does anyone know if there is a way to disable the auto-retract for the rear shade when you put the car in reverse. I generally leave the rear shade up to reduce direct sun into the car.
Originally Posted by Benush
Asked a Service Manager the same thing this spring and they said no. Something about a safety measure and DOT junk. I asked him why we could tint the windows to make them dark and they couldn't be retracted.... No reply. At one point I was going to put up the shade up and then remove the fuse or or disconnect the wiring connector so nothing could lower them, but now it doesn't matter.
Originally Posted by jftjr
Jeez, just push the button.
No, ever think that when you are parking you will go into reverse, then drive, then reverse then drive again (this is when you parallel park).
The constant down/up crap would get really irritating.
I think its best when you put in in reverse, it goes down and stays down. If you want it up when the car is parked, just put it up and leave the car in park, then turn off the ignition.
rockyboy
08-04-2024 10:35 AM
Mike Bertram
09-10-2015 09:27 AM
