Daylight Savings Time update for RL?
So, this morning I had to manually update my time, which
was no big deal. Also opted to turn off the AUTO Daylight
Savings setting.
Is there some sort of update that Acura will be offering to
fix the onboard computer so it now properly conforms to the
new Daylight Savings dates?
Thanks!
Savings setting.
Thanks!
You beat me to it. I was just about to write the same inquiry. I guess I expected more from Acura on the DST issue. The manual adjustment was so simple. But, I realized that it was the first time I had to do it during two years of ownership. Acura, are you listening?
Just turn the AUTO DST setting to OFF. That should do it.
Originally Posted by Chas2
What happens when "traditional" DST happens? Will Acura change over again in April?
'05 Acura RL - CGP/Ebony
Originally Posted by bearingman07936
Okay, so how do you change it? The book doesn't have time or clock listed in the back index.
Originally Posted by lflorack
It's in the Navigation System manual. I'm surprised the satellite didn't just download the update and/or adjust for the change appropriately. At the very least, I'd have expected Acura to tell us about it.
The part about the instructions being in the navigation manual is correct.
The part about the satellite downloading the update is just flat wrong. The satellite that the navigation system in our RL's (and many other GPS's) is talking to are the government-owned and operated GPS satellites. I'm pretty sure that they only send out GMT and let the satellites all over the world figure out the appropriate time based on software rules for DST and by calculating the time zone they're in at the time. Therefore, if I'm correct (and I'm pretty sure I am) Acura needs to update the software/firmware in our navigation systems to accommodate this change or we're going to have a 3-week gap every spring and a one week gap every fall. The satellites can't do it.
I think this is an example of Acura not acting like a true luxury brand. A true luxury brand like Lexus or Caddy will probably inform its customers of the Daylight Saving Time problem and offer some type of solution. We'll probably never hear anything from Acura about it.
Love the RL, but falling out of love with Acura in general.
Maybe it's me but I don't see the big deal. It took all of fifteen seconds to reset my time this morning. If it changes at the old date, I'll just change it again.
LL
LL
LL
LL
So, it takes quite a few minutes to get everything in shape for spring time leap ahead. It would help if the nav clock can self adjust.
They had to do the same adjustment we did since their clocks are set by GPS as well. The great Lexus didn't inform their customers nor offer a "solution." Apparently Lexus doesn't think that a couple of button pushes is that big of a deal for their owners. The owners don't seem that put out about it either.
I bet Lexus will offer something before Acura does, especially if their customers start complaining about pushing a couple of buttons. Lexus is better at coddling its customers.
I'm pretty sure Acura will make an update available soon. It would have been nice to have the update ahead of time, but it really is just a couple of button pushes to change it. I had to look in the manual myself to figure it out.
Hello all,
I think I know what's going on here. As you may know we had to change the clock three weeks ahead of the supposed schedule. Most navigation units -including our beloved RL - have a different dates already programmed in earlier on to change the clock according to your location and time zone that you enter when you go for the Setup screen. I do also, think that the navigation should interact with the satellite clock and then apply that change to our vehicles. I do not know if that is possible but it should. But updating the clock was a breeze; I changed the clock while driving back from the carwash today. It took me less than a minute to update.
Originally Posted by rama13
What's annoying is that this change was signed into law in 2005. Seems like this should have been updated back then. Lame.
OK. I caught myself after I'd had a chance to think about this.....
GPS satellites have an internal atomic clock that that was synchronized to Coordinated Universal Time (UCT), which is also commonly referred to by its old name Greenwich Mean Time (GMT), back in 1980. The GPS satellite constellation runs on "GPS time" which is not continually synchronized to current UCT. The difference is that the GPS time signal is not corrected for leap seconds, etc., and over the years, GPS time diverges from UCT. However, the GPS signal includes a correction factor for the original 1980 synch, so that GPS receivers, such as a car navigation system, can take GPS time, use the correction factor to calculate UCT, and then use your position coordinates to set a local time. The point is that the GPS signal contains the baseline time data, and the GPS RECEIVER makes the calculations to convert to local time.
So our car GPS receivers are programmed for the traditional US April and October daylight savings time, and would need a software/firmware patch.
There is some talk about a patch in the works over on the TL side
http://techinfo.honda.com/rjanisis/pubs/SN/A07030A.PDF
Pretty close. I only know about this because we support the Government in the NAVSTAR GPS program, and I started reading up on some of the technology.
Thanks for confirming my second-chance thinking and filling in the extra details related to the GPS clock vs UCT//GMT. Very interesting.
Maybe by the time I'm due for my next service, the patch will be ready.
I spoke to Acura Care on this yesterday. They explained that our clock runs off XM Radio satellite. XM is the one with the issues. I can personally vouch for this as we were XM listeners before we got this car, and our XM transportable radio does not yet show DST, so its off by one hour.
I would guess that the other car companies are in the same boat.
2012 Cadillac CTS-V Coupe
Originally Posted by GoHawks
I'm not sure that makes sense. What happens if you choose not to subscribe to XM?
Originally Posted by Mike_TX
My PC changed all by itself, and I don't even have Vista! Maybe Microsoft isn't as bad as people say.
Originally Posted by sleepinxlionhart
me too. but then again, there was an update downloaded and installed like a weekago on my PC. maybe that was it?
Okay. But XM is still behind, too.
Originally Posted by dwboston
Exactly. The "Acura Care" phone rep was wrong. The Nav system manual even refers to the time zone being read from the GPS satellite. The clocks are set by the GPS satellites. It has nothing to do with XM.
CLS 6MT Navi
You guys should be lucky enough to be customers of my local dealer who emailed me to come on in so they could provide their 'great customer service' and reset my clock due to daylight savings. Jeez!
Talk about desperate to get you in there to buy something.
just wish they had good service when you really need it.
email quote -
"You are a member of a special group – a valued customer!
We know you are busy so we are constantly looking for ways to make your ownership experience a superior one. As Daylight Saving Time approaches we recognize that you will need to change all your clocks, including those in your vehicles: You remember: “spring forward” and “fall back”.
Please feel free to stop in if you need help changing your clock. We are always willing to lend a hand. "
I guess it's a nice gesture, but I wonder what they charge to 'lend a hand'?
I guess I'm jaded on dealer service by now. I bet the great Lexus people would have come to wherever I am to reset my clock!
Come on Acura. step up! Roadside Clock Reset!
email quote -
I'm referring to our other XM radio. Its in the other vehicle, and also goes to the office and inside the house. It has a clock, and that clock is wrong.
Maybe the recent merger between XM and Sirius, put this DST on the back burner ??
Agree with most on this thread - a "true" luxury company would have at least made an attempt to notify it's customers.
I work for a storage company and we called every customer in our region (close to 600).
Time Change Brings 'Nightmare' Issues with Outlook, Calendars
Yeah! A real luxury car company should offer this stuff.
Actually, Mercedes did inform their customers about the new daylight savings time and how to change the time on the clock.
