Daylight Saving Time
You have to have the new navi DVD, version 4.62, to correct for the new Daylight/Standard time changeovers. Unfortunately, the disc is on backorder until January 2008 due to issues with the release.
You therefore need to go into the setup and change the time manually:
Press the "Setup" button, select "more", select "change clock" (or similar, forgot what it was), then adjust the time manually. You will want to uncheck the automatic daylight savings time item.
07 RL (non-tech)w/06 Nav
I just went down to the car and turned it on....when I got in, is said 3:53...several seconds later it said 2:53.
I have version 4.56 with my 05' nav unit. Now when I installed my 4.56 disc, I programmed it for "mar/nov" DST and it has worked perfectly.
If you have 4.56 (dated 5/3/06) you can set it up for the updated DST.
Originally Posted by Courage
I followed neuronbob's instructions and they worked like a charm. However, I will check the version the version of the disk I have with my 2006 RL, Larry. Thanks.
Torch & Pitchfork Posse
I beat ya! I beat ya!
I do not have the updated DST NAVI disc.
I got in the car and MANUALLY updated the clock in 4.38924 seconds!
AND that was with one arm still in a sling!
you know...i said "a few seconds" what does that literally mean....hmmm.....2 or 3 seconds...i hate to split hairs, but 4.38924 kind of rounds up to 5 seconds in my book.
But to be scientific: Several is more than a Couple,,,,but not as much as Bit, and definately more than a Few.
*ducking*
Originally Posted by TampaRL
Oh fine...split hairs with a one armed gimp.
*ducking*
*ducking*
i did in no time at all. I had my wife do it.
TLDude876
12-28-2016 03:18 PM
Rocktman1
09-19-2015 05:58 PM
