Crankshaft bearing shell failure at 120,000?
Old Jul 15, 2017 | 11:41 PM
wildcat1968's Avatar
The car was running fine and then the next day bearing knock. My question is, is it possible to remove the crankcase pan without removing the engine. I this a frequent occurrence because I have read it is a Hyundai defect, possibly a bearing manufacturer defect? The dealer said $5400 to repair and i am thining of doing myself. I m MAster Tech.
Old Jul 16, 2017 | 01:40 PM
truonghthe's Avatar
are you the original owner of the car? its not common to see a crank bearing fail at 120k miles under normal maint and driving situation.
Old Jul 16, 2017 | 04:07 PM
Turbonut's Avatar
If you're referring to the debris left in the engine during Hyundai manufacturing, certainly not the same for Acura.
Could be lack of lubrication, cruddy oil, clogged passages, etc. Usually when a main or rod bearing knock is encountered, the babbitt on the bearing is probably gone and then either the crank or rod is scored and would need machining or replacement which would call for engine removal. I've never done one, but I would say that the pan will come off with the engine in the car to do the inspection, but get ready to drop it out.
EricL
2G CL Transmission Recall Q & A
77
Dec 31, 2013 12:12 AM
FarS
Dec 1, 2013 12:46 PM
Jordy Spaur
Feb 26, 2013 07:44 AM
South Africa
2G CL Problems & Fixes
Jan 31, 2010 04:00 AM
JoganJani
Aug 15, 2006 03:39 PM
