Coolant reservoir cap
Old Sep 10, 2009 | 04:01 PM
fatty's Avatar
Do you guys know if its safe to drive with the cap cracked? Its still on the reservoir. Does it have to be sealed tight in order for it to suck the coolant? I have a 4 hr drive and i think its been cracked and just didnt notice. Looks like the tech overtightened it.
Old Sep 10, 2009 | 04:37 PM
robarsan's Avatar
You're going to start losing coolant every time the engine heats up. I would replace the cap before driving any long distance.
Old Sep 10, 2009 | 04:53 PM
fatty's Avatar
When you say losing coolant, do you mean because it will spill out through the cracks?
Old Sep 10, 2009 | 05:13 PM
robarsan's Avatar
I'm thinking of the coolant overflow reservoir, if that's what you're talking about. Being hooked up to the radiator system, it would release steam when the coolant heats up. Same as cracking a radiator cap on a hot engine.
Old Sep 10, 2009 | 06:23 PM
PortlandRL's Avatar
The cap isn't going to be astronomically expensive. I'd just replace it and not have to worry about it.
Old Sep 10, 2009 | 08:50 PM
lstevennl's Avatar
a broken cap would cause air to enter the cooling system and also under all that pressure the coolant will be forced out and youll run low. Take care of it asap or else youll be looking into some new head gaskets
Old Sep 10, 2009 | 08:52 PM
fatty's Avatar
Done, drove 1 1/2hr cuz no one had a damn cap in stock! Better safe than sorry! Thanks
vpasla1
Sep 17, 2016 07:24 PM
spudweb
May 22, 2016 02:39 PM
ROSSARONIE
Oct 2, 2015 11:46 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Skirmich
Oct 1, 2015 12:59 PM
