Conversion Units under Calculator - Anything besides temp?
Only temperature seems to be accessible. Everything else seems to be grayed out. Is there a way to access the other units?
office monkey
Odd...I have all the conversion options open to use and frequently use the automotive one since they have tire pressure in kPa here in Canada and I need to convert that to psi and I also convert my L/100km figure to the whacky mpg.
So when you put in the number and press down with the control stick it takes you to the menu of choices and only temp is able to be selected? I have no clue why that is so.
Temp is the only thing that is selectable in my menu. All the other units are grayed out.
Enter a value, then the others will open up. Temp is the only one that converts zero to other values.
I didn't realize you entered the numbers in on the calculator screen.
All is working correclty.
spoiler900
10-10-2015 06:48 PM
Eggs999bacon
09-24-2015 10:08 AM
