charging port next to shifter
Most likely in the fuse board in the driver side kick panel. It's also possible the bezel around the shifter was removed and the wire was removed or damage and never reconnected?
I removed it to install GROM unit. But put it back the right way. No broken wires plugged it in correctly. Which number fuse is it?
Without going to the car, I don’t remember off the top of my head. The cap/lid you remove to access the fuse box has each fuse assigned on it.
There's a VERY detailed manual available on this site that has all that info in it. If you can't find it, email me at plohmeyer@woh.rr.com and I'll try to send you a download.
Well at least it was simple!
