car wont rev past 5500 rpms?? hits rev limiter
Old 08-15-2017, 09:50 AM
jmoney2001's Avatar
hey guys got a weird issue with my car. it wont rev past 5500 rpm no matter in what gear in either sport mode or automatic while driving. in part it just revs to about 4900 then hit rev limiter which i assume is normal. i have already reset the ecu and did the drive by wire throttle reset still the same. my snap on scanner did not pic up anything. is this normal?? any one else with this issue i have searched the forums and no one has my specific issue. car is a 2005 acura rl 3.5 170k
Old 08-15-2017, 09:57 AM
Received 16,266 Likes on 11,974 Posts
have you checked oil level? make sure it's at full line.
Old 08-15-2017, 10:21 AM
jmoney2001's Avatar
yes oil is good
Old 08-15-2017, 10:24 AM
if oil level is good, then it may be the APP sensor?
does the RL even have an APP sensor?
Old 08-15-2017, 10:55 AM
jmoney2001's Avatar
yes from my understanding its a fly by wire system. do you happen to know what the car hits rev limiter in park??
Old 08-15-2017, 10:58 AM
in park, it doesnt red line. the max RPM it reaches is like 5500.
redline is 7200 RPM.
if the car doesnt reach the red line, means either low on oil or APP sensor.
Old 08-15-2017, 11:14 AM
jmoney2001's Avatar
i will have to look into the app. my car in park will only reline at 4900 rpm. i know its supposed to be lower just didnt think this low
Old 08-15-2017, 11:17 AM
dont worry about what it does in park. because that's the max RPM it reaches.
you should ONLY be worried about why it isnt going to redline 7200 RPM in drive and under load.
vtec starts at 5500 RPM. the cam switches profiles, so if low on oil it wont go into the HIGH RPM range.
also, may be vtec actuator.
may be APP sensor.
Old 08-15-2017, 12:34 PM
jmoney2001's Avatar
how would i go and check to see if vtec actuator is working
Old 08-16-2017, 04:42 PM
truonghthe's Avatar
Received 1,692 Likes on 1,307 Posts
any code pop up?
Old 08-16-2017, 05:40 PM
jmoney2001's Avatar
No codes.
