Cabin Air Filter
Cabin Air Filter
Just changed mine with a NAPA filter for $20.00. Question is should the air flow arrows be pointing down or up? For those that have not done this, it took 2 minutes and after 10,000 miles was filthy. Thanks!
What made you check at 10000 miles?
Did you also check/change your air filter?
Thanks.
Also, FYI,the air flow (down arrows) indicated on the front of the filter housing.
Changed at 10,000 miles. It was dirty. Than I was just checking to see one if I could get to it and two if it was dirty. I got 21,000 miles now. Thanks for the info for pointing down, wasn't sure.
rcs86
08-02-2016 06:52 PM
