View Poll Results: A/C PROBLEM STILL BLOWING WARM AIR
A/C
100.00%
Compressor
100.00%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
A/c
Old Jul 26, 2025 | 10:12 PM
Zack_elb716's Avatar
3rd Gear
A/c
Hello everyone,
so here is my issue im stuck at atm. My compressor stopped working , so I ordered a new compressor and Ac fan , I replaced them both and tried recharging but it was holding pressure but not taking freon, so I changed the ac pressure sensor and still the same thing, I changed the high pressure and low pressure line still the same issue , the mechanic vacuumed the lines 3 times and still same issue (holding pressure but not taking freon) I took it to a A/C specialist, they said I need a new condensor and a A/c expansion valve , and while changing those 2 i need to flush the system, so I ended up changing those 2 and flushed the system, after putting back everything still the same issue, its holding pressure and not taking freon ... what can I do now
Old Jul 28, 2025 | 10:06 PM
TonyCD's Avatar
Note from somebody smarter than me:
"No one mentioned the drier/accumulator. Should be replaced whenever the system is opened. I’d evacuate the system, replace that, and try again."
Old Aug 2, 2025 | 03:52 PM
3rd Gear
I will give that a try , thank u.
