bulb or ballast?
bulb or ballast?
So i changed my driver side low beam hidhelp light on my 2006 acura rl about a month ago and it worked fine up until earlier today. Had no changing of color just went out without warning. Once i turned the lights on and off i could see a flicker for aboit 2 seconds then back to nothing. Has anyone else had this problem or know a solution. Plz help
What kind of bulb did you replace it with? You could move it over to the other side to see if it is the bulb or ballast/ignitor.
justnspace (02-17-2015)
