brakes squeeking
Old 05-06-2010 | 04:36 PM
ndmx1000's Avatar
brakes squeeking
Hey all
Seems like my back brakes are squeeking and wondering if i should replace both the rotors and brake pads. If you have any insight on this and any recommendations on good value brake pads and rotors that would be awesome. Thanks.
Old 05-06-2010 | 05:01 PM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Originally Posted by ndmx1000
Hey all
There is a TSB for this if it applies to your RL and warranty situation,,,,
http://www.in.honda.com/rjanisis/pubs/SB/B07-029.pdf
Old 05-08-2010 | 05:44 PM
rlerman's Avatar
how many miles are on your car. Brake squeaking is not necessarily due to rotors, more likely your pads are worn and/or your shims no longer have anti squeal grease on them. Pads are about $70 for the rear. Akebono proact ceramics have worked well for me.
Your rotors are worn if you can feel a lip on the outside edge of the face. if there is no lip, you are in good shape.
Old 05-09-2010 | 12:00 AM
037's Avatar
037
if you want better braking, look into Satisfied GranSport 6 on TireRack. They cost about the same as OEM but are a huge improvement.
I am using them with StopTech rotors, slotted.
Old 05-17-2010 | 04:56 PM
ndmx1000's Avatar
thanks
hey guys thanks for the help. I have a 2005 rl with 98k miles btw. I am going to replace the pads with http://www.amazon.com/Akebono-ACT109...tive&carId=001. I think. Gonna check out the rotors too.
Thanks again
Old 05-17-2010 | 06:06 PM
037's Avatar
037
I wouldn't waste my money on pads which are same or lower quality than stock, that's just wrong.
Old 05-17-2010 | 10:26 PM
phishfood's Avatar
I've had a Toyota around in one form on the other now for about 20 years. One thing I learned is buy the pads from Toyota. Aftermarket stuff (unless it's the Good Stuff) is usually crap.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
rockyboy
10-02-2015 10:45 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: brakes squeeking
