B16 service indicator showing
Old Mar 7, 2010 | 08:41 AM
asookazian's Avatar
Hi, I have a 2006 RL. The B16 is showing. I've read this is basically an oil change.
At what mileage intervals does that indicator turn on/display? 3500 miles or what?
I usually change my oil in previous Acuras around 5K miles. thx.
btw, does the SH-AWD really handle better than "normal" cars? It doesn't seem any better handling than my 2000 TL (but maybe it's better in the rain?) And it doesn't seem to out-accelerate my old TL either. Otherwise, a very nice car.
Old Mar 7, 2010 | 09:07 AM
robarsan's Avatar
B16 is more than just a basic oil change. Letter "A" is just the oil change, "B" is a long list of components they inspect; see page 357. "1" = rotate tires, and "6" is change the differential fluid.
The display will activate when the remaining oil life is 15 to 6% with "Service Due Soon".
The SHAWD excels in cornering and driving in snow much better than "normal cars" in my opinion.
Old Mar 7, 2010 | 09:59 AM
TampaRLX-SH's Avatar
Torch & Pitchfork Posse
Page 357 & 358of the Owners Manual covers the MID Service codes:
http://techinfo.honda.com/rjanisis/p...606O00355A.pdf
B16 Maintenance Main Items:
Replace engine oil and oil filter
Inspect front and rear brakes
Check parking brake adjustment
Visually inspect these items:
Tie rod ends, steering gear box, and boots
Suspension components
Driveshaft boots
Brake hoses and line (including ABS)
All fluid levels and condition of fluids
Exhaust system
Fuel lines and connections
AB
Symbol
1 - Rotate Tires
Symbol
- Replace rear differential fluid
Driving in mountainous areas at very low vehicle
speeds or trailer towing results in higher level of
mechanical (shear) stress to fluid This requires
differential fluid changes more frequently than
recommended by the Maintenance Minder. If you
regularly drive your vehicle under these conditions,
have the differential fluid changed at 7,500 miles
(12,000 km), then every 15,000 miles (24,000 km).
If the message ‘‘SERVICE DUE NOW’’ does not appear more than 12 months
after the display is reset, change the engine oil every year.
See information on maintenance and emissions warranty in the first column
on page .
Independent of themaintenancemessages in theMulti-Information
Display, replace the brake fluid every 3 years.
Inspect idle speed every 160,000miles (256,000 km).
Adjust the valves during services A, B, 1, 2, or 3 only if they are noisy.
Old Mar 8, 2010 | 10:41 AM
armashi's Avatar
Tampa, do you service your car at Crown or Ferman or Honda? Do you know of a private mechanic with better prices than the dealer?
Old Mar 8, 2010 | 05:11 PM
Sent you a PM
Old Mar 9, 2010 | 10:17 AM
asookazian's Avatar
what about in the Glendale, CA 91208 area? I took my 2000 Acura TL to Jason's Honda/Acura specialty and leary of taking my RL there (I spent $1K and got a new alternator - the battery was overcharging @ 18.8V - and drove away with 3 non-functional windows and non-functional stereo).
Dealers are expensive.
Have taken to Sears in the past...
Old Mar 9, 2010 | 10:20 AM
asookazian's Avatar
But how is that 15% or 6%, for example, calculated or based upon? Surely the computer does not know how dirty the engine oil is. Total miles to 5000 miles, for example? usually the stickers they put on the windshield are "set to expire" in 3500 miles, no?
It's almost 1000 miles over...
Old Mar 9, 2010 | 11:17 AM
robarsan's Avatar
Per the owner's manual:
Based on engine operating
conditions and accumulated engine
revolutions, the onboard computer in
your vehicle calculates the remaining
engine oil life.
So basically, it's based on acumulated miles, engine temps, time.....etc.
Old Mar 12, 2010 | 06:11 AM
GoHawks's Avatar
2012 Cadillac CTS-V Coupe
The B16 just displayed on my car a few weeks ago. With regard to the inspections,my dealer performs a "courtesy inspection" of most of the items listed above everytime I take the car in for service, regardless of whether it's called for. They then give you a sheet highlighting the condition of the inspected items. As a result I just ask for the "real work" to be performed. In this case the oil/filter change, tire rotation and diff oil change.
Much cheaper.
Feb 25, 2020 09:57 AM
Sep 17, 2015 10:16 AM
asahrts
Sep 4, 2015 05:55 PM
