B pillar Creacking Noise (Driving me crazy!)
My 09 RL has been bothering over two years.
The sound will be heard when the body is a little twisted, and also the vehicle starts and stops a little abruptly.
When I'm driving at a speed of 50-60 there's no sound. Many suspension parts have been replaced (Strut, Lower and Upper control arm, stabilizer link, and bushing.
I didn't catch the exact area, but I think there's a sound around the B-pillar.
Can the sound be heard around under carriage cover?
Is anyone having the same issue with this and has solved it?
https://youtu.be/1KtSywTNMPI
Have you treated the door seals recently? Actually, all seals including the sunroof and boot/trunk should be done regularly.
Also, try cleaning your seat belts/guides. They could cause creaking on S2000s, because of course, they get dirty very quickly if the roof is never up.
Sorry for the toenail :0
Yesterday, I wrapped Tesa tape on that and I was driving with the door open, but unfortunately, the noise was not disappeared.
I applied a light grease to the seals, and even when I was driving with the door open, the sound came out. So sad.
Then I'm running out of ideas!
Last shot - my rear sunblind sometimes creaks on bumps, unless it is raised.
Sounds can travel all round a monocoque body - loose spare wheels or bonnet/hood latches on S2000s sound like interior trim creaks, too.
Hi,
I am a little late with my answer. I had a similar problem with my 2007er KB1. I had to spread the gap between the two metall sheets, and glued it with epoxy. Then the noise was gone.
That's a strange one!
Looks like they might have placed two spot-welds too close together and there's a tiny bit of movement in the bodyshell. But then I didn't calculate the bodyshell...
Being such a low-volume car, perhaps they are welded by hand and not by robot.
