Autoleveling Question
The RL's headlights have an autoleveling function. Does this kick in when driving normally, or just when loading that 300 pounds of shelled corn and birdseed into the trunk?
With all the discussions about headlight aim, it's occurred to me that no one has questioned whether autoleveling comes into play.
The first time I saw the feature touted was on a 3 series Bimmer I test drove several years ago, and perhaps wrongly, I had the impression that the headlights would autolevel when driving.
FYI, love the headlights now that they are aimed higher.
No, you are a dork.
Originally Posted by CGTSX2004
The mechanism doesn't react fast enough to do it while driving. It's intended to help maintain a consistent headlight level when you load up the rear end. No autoleveling mechanism is capable of functioning to react to the constantly changing road conditions.
I doubt it is able to react to every bump in the road. To road gradients maybe, but certainly not bumps in the road.
Long ago and far away, a grey market Maserati Biturbo found its way into the hands of a friend of mine... it had a wonderful feature -- a dial on the dashboard to allow you to adjust, within a range, the height of the headlights.
That, and the dash clock, and the suede headliner, were the best parts of that car.
Trying to adjust Weber carbs in a pressurized plenum box, however, and running the risk of fouling the spark plugs if you didn't operate the MANUAL CHOKE just right on starting, however, were the worst.
AcurAdmirer
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by Mike_TX
And the humble Nissan Murano has that to this day ... ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by mrdeeno
so is Nissan/Infiniti the only automaker that has this feature in some of its cars in the U.S.?
The Q45 was probably the first Nissan/Infiniti to have them, and the QX56 I know has them.
The adjustment on the dash is considered a "cheap" alternative to the real thing.
1 Post
Originally Posted by db22
I find it hard to believe that Infinity does not had Auto-Load Levelling. With this feature the headlight adjustment is superfluous.
Do research and learn to spell.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Infiniti has auto-leveling headlights.
Do research and learn to spell.![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I was worcking on my resurch progect as to y a Nissan Oner was in this phorum butt I cood not find the spelchekur - sorry.
Originally Posted by stingerbtry
I'm guessing he is or was at one time an Acura owner:
'05 Acura RL - CGP/Ebony
I just did some research and I don't think ANY acura model has auto-leveling headlights...even the RL.
Can someone look in the driver's manual or somewhere else to confirm this?
1 Post
If mrdeeno was an RL owner then he probably wouldn't be asking if "anybody could look in the owners manual", he could do it himself. I know he can read because he sure can spell.
1 Post
I said Acura, not RL. Not sure why anyone whould post that much on a car forum if not.
but really...i had a cl-s that got stolen and shot up.
AcurAdmirer
I am surprised that the Nissan has them as well but they are French aren't they?
(Okay, okay ... Nissan owns a bunch of French carmaker Renault's stock.)
Originally Posted by lflorack
It's mentioned in the RL's AFLS demo video on the Acura site. It sounded like it's only for loading compensation.
1 Post
Manufacturers assume, correctly so, that if you auto level the car then the headlights will still be aimed correctly. If you have a manual adjustment on the dash one must assume that the car does not have load leveling.
The RL has auto-leveling of the headlights...not the car.
Further, I find it hard to believe that Acure does not have auto-leveling headlights for any other car besides the RL. The MDX doesn't even offer HIDs. I guess not offering ANYKIND of leveling adjustment (short of popping the hood) on most of their models is considered the "CHEAP" alternative to the real thing.
The posts regarding the effectiveness of the RL's headlights have been all over the board and this is why I previously checked the manual and then posted after speculating in my case whether autoleveling is affecting the effectiveness of my RL's headlights and what I consider to be very poor performance in that regard.
1 Post
The autoleveling function is part of the adaptive front lighting system. Section 22-237 of the service manual shows the location of the components. The adaptive front leveling sensor is on the rear suspension and the motors are up front. There is a headlight leveling sensor, along with other sensors and adjuster motors. The leveling sensors react to vertical movement (22-239). Along with tests for the various functions, the service manual additionally details a "learning" procedure for the headlights.
My M45 has adaptive as well as auto-leveling headlights, but the auto-leveling I can't "perceive" working. The headlights were actually aimed too low (reportedly a common problem) from delivery, so I had to crank them up a little.
I don't know if the auto-leveling should be perceived by the driver or not...maybe its one of those things that you know works when oncoming traffic doesn't constantly flash their highs at you.
I think with these projector headlights, automakers are being "safe" in aiming them lower than needed at the factory. And with the sharp cutoff, it "appears" that they are aimed too low, when in fact they are in the "acceptable" zone, but can also be raised slightly and still be acceptable.
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
