Anyone need a stator for '05 RL AC?
Old May 23, 2014 | 07:25 AM
rb95gs's Avatar
My '05 RL was blowing only warm air so based on their failure history I bought a new stator to have on hand before getting into it. But I should have checked the car's built-in diagnostics first. It showed the ac pressure switch was "open" so I looked and found the switch was still unplugged from when I did the timing belt and valve adjustment last fall. DOOH!
Old Jun 3, 2015 | 01:14 PM
minla007's Avatar
pumpkin escobar
hello, I have the same issue with my A/C blowing warm air. This issue started happening after my timing belt was replaced by a Honda mechanic.
Can you help me locate this 'switch' that you are referring to? Maybe mine was also not reconnected after the timing belt job & I would like to check it first and try to reconnect it (if it is disconnected) before taking it to the dealer.
I went into the navi diagnostic mode and have attached images of what I found.
Your help would be greatly appreciated. Thanks.
Attached Thumbnails Anyone need a stator for '05 RL AC?-20150603_133428.jpg   Anyone need a stator for '05 RL AC?-20150603_133531.jpg
kingofbytes
Sep 11, 2015 09:29 AM
bamachem
Aug 17, 2012 03:29 PM
markd27
Aug 7, 2011 11:14 AM
tnobori1
1/2G MDX (2001-2013)
Feb 7, 2011 06:47 PM
TheWeez
Feb 25, 2007 11:01 AM
