Anyone need a stator for '05 RL AC?
My '05 RL was blowing only warm air so based on their failure history I bought a new stator to have on hand before getting into it. But I should have checked the car's built-in diagnostics first. It showed the ac pressure switch was "open" so I looked and found the switch was still unplugged from when I did the timing belt and valve adjustment last fall. DOOH!
pumpkin escobar
hello, I have the same issue with my A/C blowing warm air. This issue started happening after my timing belt was replaced by a Honda mechanic.
Can you help me locate this 'switch' that you are referring to? Maybe mine was also not reconnected after the timing belt job & I would like to check it first and try to reconnect it (if it is disconnected) before taking it to the dealer.
I went into the navi diagnostic mode and have attached images of what I found.
Your help would be greatly appreciated. Thanks.
kingofbytes
09-11-2015 09:29 AM
bamachem
08-17-2012 03:29 PM
