Adjust headlight height?
Old Jun 10, 2010 | 10:18 PM
PixelHarmony's Avatar
Master Graphic Artist
I remember on my TSX I could use a Phillips screw driver to adjust the height of my low beams. I was wondering if there's a way to raise the RL's low beams during highway driving it seems to cutoff closer than I would like... Also is it just me or are the headlights not as bright as the TSX or S2000?
Old Jun 10, 2010 | 10:27 PM
Chas2's Avatar
Yes you can adjust it as you describe. Search for a thread on this. There were reports of people adjusting it upwards too much, and had to replace the entire headlight unit at hundreds or thousands. I think they stripped the mechanism or something. It was back in 2006 maybe???
Old Jun 11, 2010 | 08:10 AM
db22's Avatar
The plastic cover next to the fenders show a hole with a rotation up/down. Use a flashlight to locate an orifice that a #3 philips will fit into but it is not a philips screw. It is about 3 or 4 inches down the hole and you will need a long screwdriver. It takes many turns to move the lamp so I typically park 10 feet back from the garage door and move the light beam and then test it by driving at night. 1 inch up on the garage door is a long way different up the road so go in small increments so that you do not run the thread out. The thread dissengaging is the $$$$'s part.
hashbrown
Feb 18, 2022 11:20 AM
Mike734
Dec 10, 2021 01:25 PM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
4drviper
Sep 23, 2015 07:42 PM
