acura RL 2009 VSA and SH-AWD lights on
Old 01-03-2016 | 11:35 AM
silvio65's Avatar
i have a 2009 acura rl i did some collision repair and mechanic as well
my vsa and sh-awd lights are on !!
i took the car to dealer thinking they where going take care this problem they did NOT. i tried erasing the code and they come right back ! can you please help me !!
mechanic told me i need to do AFS memory and steering angle sensor reinitialize, and neutral switch too.
anyone help ??
Old 01-03-2016 | 02:12 PM
oo7spy's Avatar
Have you checked the fluid levels in your rear diff? What are the codes you are getting?
What do you mean the dealer did not take care of the problem. Did you pay the diagnostic fee? What did they tell you was wrong?
Old 01-04-2016 | 10:39 AM
teh CL's Avatar
definitely find out what those codes are
Old 06-18-2016 | 09:17 PM
abercash's Avatar
I have this same issue on my 2008 RL if anyone has any updates on if silvio65 was able to resolve the issue and how that would be much appreciated.
Old 06-20-2016 | 12:21 PM
Tubasteve's Avatar
First thing, 08 and 09 rl are different awd system, but similar issue would be the steering angle sensor being out of center. Best thing to-do is read the codes and it could help. Unfortunately it might not be a matter of just replacing a part and clearing the code.
Old 06-20-2016 | 12:32 PM
abercash's Avatar
Thanks. I have a question regarding reading the codes. There are OBD codes thrown and the there are no codes being written to the Nav screen (if that makes sense). So my question regarding reading codes is, do you mean I need to take it in to have it read by a Honda Diagnostic reader?
So far, I have pulled the rear wheel sensors and blown off the junk that had accumulated on those and reinserted. The issue is intermittent currently. It seems to be triggered by hard road bumps or turning and hitting a hard bump.
I'll take any ideas or suggestions prior to being forced to take it in.
Old 06-20-2016 | 12:33 PM
abercash's Avatar
Sorry, I need to proof read my own writing. It should have read There are NO OBD codes thrown.
Old 06-20-2016 | 12:41 PM
Tubasteve's Avatar
Not Acura or Honda, just need someone with a decent scanner. Snap on Solis can read and reset it steering angle(just an example).
The code is stored in a body control module for afs. I had a code for afs, vsa, and awd.... Was brake switch, code would fault it stop and go. There are suspension angle sensors for the system as well.... Get the code, gets the answer.
Old 06-20-2016 | 08:51 PM
oo7spy's Avatar
How so?
Old 06-20-2016 | 09:31 PM
Tubasteve's Avatar
Originally Posted by oo7spy
How so?
Mechanics are similar, but the biggest being the implementation of the sh-awd is in the software. The imu(s) accsessed during the drive are typicly "better tuned". The biggest change is at which the awd system now takes over first gear on the 09+ sh-awd, where as the 05-08 did not. The applied engine power to the wheels are less agressive in the rear to help improve mpg from driveline loss when adding more power to the rear (eh) thus giving it closer to a fwd car when cruising. There is less latency in the responce of the system, but by the data no human would detect. The coolest thing is when you look at an older units data, compared to the later is just how fast the data is being calulated over time, where as the older one would lean heavily on other sensors for the correction of the wheels.
Old 06-26-2016 | 03:12 AM
spheregrid's Avatar
a few years ago i had a similar issue with vsa and sh-awd lighting up after starting my car.
only found out it was my faulty brake sensor . brake lights would light up sometimes.
but i remember when i turned on my car no vsa and sh-awd would light up until i step on my brakes
10$ part to replace the sensor switch under the brake pedal. worth a shot.
Old 06-26-2016 | 12:27 PM
abercash's Avatar
Thank you for the idea. I haven't found any one who has a scanner that can pull the codes mentioned above and my add to sell my kidney in mexico pay for my own has yet to yield the money I need. I will order that switch today. I've replaced a couple of those for others on hondas and acuras. So for $10 it's worth a try.
Old 06-30-2016 | 07:59 PM
pcloadletter's Avatar
A Honda HDS tool is needed to reset the vehicle neutral sensor which clears the VSA fault on a lowered and realigned 2009 RL.
rockstar143
04-24-2020 06:59 AM
acuraguyrlx
3G RLX Problems & Fixes
04-27-2017 10:48 PM
3GTLOwns
4G TL Problems & Fixes
12-21-2015 03:00 PM
levelseventysix
12-20-2015 07:36 PM
Quick Reply: acura RL 2009 VSA and SH-AWD lights on
