Active Front Headlights (AFS) Warning Light?
Headlight Sensor
Update. The Toyota sensor corrected the problem for 3 weeks and 500 mi. Then I started getting the error again. So I ended up installing the 2.2k resistors in the old part. So far so good.
My fix worked for about 3wks/500 mi and then I got the error msg again. So I did the resistor fix to the old part. Let me know how the Toyota part works for you. bmwjackson@gmail.com
The actual lowering arm is quite rusted. Is this something I should replace? Or will cleaning it off with WD-40 be enough?
The 10mm nut loosened the arm but just spins and spins so I assume it does not come off and the sensor will drop out from the back once I detach the plug (which is caked in mud) and remove the screw? The plug is really on there. I started with the arm but it just spun and spun and then I could not detach the plug but she's been attached for 18 years. I did not want to ruin the connectors.
Tomorrow is a new day but frustrating as I thought that this would be a quick swap.
The shaft has two flats that fit into flats in the arm. The arm can stop the shaft from turning. Also the shaft shouldn't just turn because internally the little device can't rotate a full circle. Good luck.
I took another crack at it. Unfortunately it appears as though I’ll need the entire component as mine is severely rusted. The main arm started to crumble as I loosened the bolts. The whole assembly goes for $150 on eBay which is crazy. Going to check local yards. Hate how this is becoming a major project. I also discovered a major rodents nest in back of the wheel well liner. Sprayed the hose up inside it and a ton of leaves and acorns came out.
I have a new sensor but the mount and lowering arm which it goes into is way beyond its service date.
Still worth a shot to put in the new sensor?
Jacobpockros
Dec 4, 2009 09:23 AM
