A12 Service Due
A12 Service Due
Hey guys, I have not been able to get a straight answer on what all is needed to be done on a A12 service. I have searched here and I mostly get A12 service info for TL's, and its rather conflicting. I have also tried looking through the PDF Owners Manual but this computer will not open them. I just dont want to get screwed by the stealership when I take it in next week. I also wanted to know if any fellow RL owners have had any problems with the front suspension. I keep hearing some clanging noises in the front right side, it sounds like metal pieces are loose when driving at low speeds and you hit small bumps or uneven roads. I also here lots of road noise on the freeway, it sounds like it may be a bearing or something. Any info or suggestions will be greatly appreciated.
A12 is Engine Oil change, replace air cleaner element, replace pollen filter, check drive belt and rotate tires. Pages 357 and 358 of the '06 Owner's manual.
No suspension problems here.
LL
Torch & Pitchfork Posse
Save yourself $30 - $50 off the service visit and change the cabin air filer yourself. Maybe even the engine air filter.
Always ask the charges when you make your appointment. Then ask what the charge is without the cabin or air filter.
You may also have a loose heat shield causing the rattle.
is the drive belt and timing belt the same thing? i have an A12 service minder that came up but wanted to do it all DIY. i'm pretty versed on the oil/filter changes but how do i inspect a drive belt? thanks. i have an 05 RL
The Box
Drive belt is a serpentine belt which is what you see on the outside. The timing belt is internal and involves a lot more work and expertise.
Drive belts aren't difficult to do yourself, timing belt I don't think I'd ever attempt.
^ off topic but i would love to see a pic of your mdx shifter in the RL, if u can post one. pls lol
