"A1" servicing at 20K miles
Old Jul 2, 2007 | 12:08 PM
AllenRL's Avatar
Anyone know what this is suppose to include? How much did the dealer charge you guys for this service?
Thanks,
Allen
Old Jul 2, 2007 | 12:12 PM
Chas2's Avatar
My dealer is a rip off and charges $100
A=Replace engine oil
1=Rotate tires
Look in the Maintenance Minder section of the OM. Pp 357-358 in the 2006 OM.
Old Jul 2, 2007 | 12:28 PM
AllenRL's Avatar
That is nuts! I am going to get this done on my own!
Anyone know how to turn off the the reminder if I do this "service" myself?
Since this ia a AWD car, how should the tire rotation go?
Thanks!
Old Jul 2, 2007 | 12:31 PM
jftjr's Avatar
'06 RL
Thanks!
Insert obligatory "RTFM" comment here.
My dealer charges about $70 for that service... not worth my time to shop around for it, really. Jiffy-Screw will charge me $25 for an oil change, but it's not worth it to have my oil pan plug stripped out and my filter mis-installed, either.
Old Jul 2, 2007 | 12:43 PM
andrewmr's Avatar
1=Rotate tires
Aren't there a bunch of check and inspect things on the list to do at that interval?
My dealer charges $35 for an oil change if that's all you were having done.
And I don't rotate my tires....
Old Jul 2, 2007 | 12:48 PM
jftjr's Avatar
'06 RL
"A" service is just oil change. The "B" service is the "inspect and check".
Old Jul 2, 2007 | 12:52 PM
medrxman's Avatar
May I ask.."Why don't you rotate your tires.?"
At almost $300/tire I think you would eventually save money by having equal tire wear. With front drive only I could accept not rotating and just buy 2 more when neeeded, But with AWD I beliebe you would be well advised to rotate.
Old Jul 2, 2007 | 01:17 PM
Chas2's Avatar
Thanks!
P. 352 of the 2006 OM tells you how to reset via Mantenance Minder menu access.
P. 385 gives you the pattern depending on the type of tires you have.
I am not trying to be sanctimonious with the OM quotes, by the way, so don't take it that way. The OM and this forum are where I get most of my info on this complex car.
The link at the Tire Rack gives similar info, but more expansive, covering different variables such as driveline, wheel size, tire type. Just as the OM says, you would use Tire Rack diagrams C or D depending on the type of tires you have.
http://www.tirerack.com/tires/tirete...currentpage=39
Old Jul 2, 2007 | 04:01 PM
gavine's Avatar
For those who don't have their owner's manual handy, here are the steps to re-set the reminder:
1. Turn the ignition switch to the ON (II) position
2. If the oil life minder is not displayed, press the SEL/RESET button on the steering wheel repeatedly until it is.
3. Press and hold the SEL/RESET button on the steering wheel for more than 10 seconds and the remaining engine oil life reset mode will be shown on the MID
* To reset the engine oil life, press the up or down button to select RESET on the display and press the SEL/RESET button to select it.
Old Jul 2, 2007 | 04:58 PM
AsianTL's Avatar
Asian07RL
1=Rotate tires
My dealer charged me around $40.00 for A1 service. First oil changed free.
Old Jul 2, 2007 | 11:00 PM
Chas2's Avatar
$40 is how much they charge me with no tire rotation. What a rip off they are...DC prices.
A nice jack, a 22mm deep socket and a torque wrench, but who has the time?
Old Jul 3, 2007 | 07:28 AM
andrewmr's Avatar
Thanks, I'm still learning about these "A" and "B" things. Then that does seem a little out of line as I said, my dealer charges $35 for an oil change.
Well, it's a long story. My other car (Turbo Porsche) has different size tires front and rear and they're directional so I can't move them.
On my girlfriends car (BMW 528 Sport Wagon) every time we rotated the tires we ended up with a noise (tire related) so we just left them in the original spot. We got 55K on her first set of tires and 50K on her second set or tires.
My car (2005 RL) tires have 53K on them with a little wear on the inside edge of the rear tires but I will make it till the winter before I replace the tires.
Could I get more mileage out of them if I rotated them, maybe. Am I happy with them so far, yep.
Oh, I do that kind of work myself so it wouldn't cost me anything to rotate them so it's not a money issue. And I love tinkering on my cars so it's not a time issue.
Michael
mada51589
Jan 9, 2025 04:40 PM
Zonian22
Nov 14, 2015 01:20 PM
IIDXholic
Oct 8, 2015 07:53 AM
1Lieutenant
4G TL Problems & Fixes
Sep 10, 2015 08:39 AM
asahrts
Sep 4, 2015 05:55 PM
