245/35/20?
Old May 31, 2013 | 01:53 AM
TorontoSars's Avatar
8th Gear
245/35/20?
Hi,
I know the recommended tires size on 20" rims is 255/35/20 but does anyone know if 245/35/20 ok to run?
Old May 31, 2013 | 02:33 AM
BDoggPrelude's Avatar
Who says the recommended size is 255/35R20? A 245/35 is actually closer to the overall stock diameter.
245/50R17=26.65" Diameter
245/45R18=26.68" Diameter
245/35R20=26.75" Diameter
255/35R20=27.03" Diameter
Personally, I went with the 255's for two main reasons. First, I wanted a little bit wider tire than the stock 245's. Second, most 20" wheels are at least 8.5" wide, (1/2" wider than stock), so wrapping them with a little bit wider tire makes sense.
Old May 31, 2013 | 02:37 AM
And this should probably be posted in the wheel/tire/suspension sub-forum BTW.
Old May 31, 2013 | 12:23 PM
M T L T L's Avatar
Its actually the "wheel tire suspension sub forum" that is misleading towards 255
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/proper-tire-wheel-sizes-rl-498227/
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
63
Mar 23, 2016 02:13 PM
sunny201
38
Apr 30, 2009 07:29 AM
xinminn
Feb 24, 2009 12:14 AM
heyitzalex
Sep 29, 2008 02:09 AM
