2011 Acura RL Condensation Driver's Side Mirror (Help)
Out of the blue I am getting condensation in the side turn signal lens of the mirror. Is there a guide someone has on how to remove this lens? I will just buy one and replace it instead of trying to fix it but do not want to damage the mirror.
Did you run a search? There's multiple threads related to what you're trying to do.
If you did and couldn't find anything here's the process.
-Insert a trim removal tool on the bottom of the mirror and pry outwards to pop out mirror.
-Disconnect the two black mirror defogger wire behind the mirror
-There will be one screw holding the turn signal indicator
-Slide indicator to the right and unplug the connector.
Install in reverse order. See my power folding mirror thread below in my sig for more details.
Hope that helps.
Hope that helps.
oo7spy (01-29-2015)
Hope that helps.
Hope that helps.
Soul_Deamon
11-13-2018 04:44 PM
nanos
11-12-2015 08:41 PM
