2008 RL 200,000 miles
I'm looking to purchase a 2008 RL SH-AWD in excellent condition for sale ( $5,000) at a local Acura dealership. It has 197,000 miles. Great maintenance records. My greatest concerns are the transmission / AWD system. Should I purchase or walk away. Any suggestions appreciated.
Thank you
Thank you
Manually up and downshift each gear while driving to make sure there isn't any slipping/grinding/significant hesitation/etc. While parked, do multiple changes to drive/neutral/park/reverse to make sure it quickly and seamlessly shifts into gear with no major jerks or noises.
Check the ATF to make sure it doesn't smell burnt and is reddish rather than straight brown. Reddish-brown is acceptable of course but straight up brown is no bueno.
Check out the tailpipes to make sure there isn't excessive soot which could be due to oil consumption or significant engine wear.
Take some sharp corners to allow the SH-AWD system to kick in to make sure it's working correctly.
Sigh ... dealers... they would overprice anything and everything like their life depends on it... I bet they paid 300$ for that trade in...
HEAVY_RL (03-21-2019)
Thank you
Thank you
For you, $1500 + some of the part maintenance and timing belt service you need to do - it would come out roughly speaking under $5000 anyway once you invest some into part replacements as needed to make it last at least couple of years... although it will outlast any expectation I guarantee you that (unless it was beat up lol)
Thank you
Thank you
I have seen a lot of RL's with over 275k miles and they are as smooth as butter. Usually I look at the interior of the car to judge its mechanics, people that take care of the interior also take care of everything else. But no matter what I would talk down the dealer.
Obviously the engine and transmission are the important items here but be prepared for other items to need repair eventually. Suspension components are going to be considerably worn after 200k miles. Bushings will be cracking and loose. Accessories may eventually die, such as the alternator, power steering pump, radiator, etc. Ball joints, wheel bearings, brake master cylinder, calipers, the list goes on and on.
It's not to say any or all of that stuff will go. Chances are only a couple will bite the dust. But you'll want to be prepared to either fix it yourself, or pay a mechanic a small sum when something dies.
