2007 RL struts
Old Jan 25, 2019 | 04:08 PM
Nescu777's Avatar
2007 RL struts
Hi everyone
so I'm trying to get a little help, I need to change my front struts and I've found the original parts from acura and they are kinda expensive
i looked it up the same part no that Acura has for struts at honda oem's and they have the same part no at a much lower price
my question is do the part no's fit both acura and Honda, so if I'll buy the part no that I need from Honda would it fit my 07 acura
thank you
Old Jan 25, 2019 | 07:01 PM
stevieray's Avatar
2007 LSM KB1 Tech w/CMBS
No but KYB is a good aftermarket replacement shock for the KB1. The OEM shocks are hideously expensive and also have a design flaw. There's a plastic component in the OE shocks that breaks and makes the shock lock up. Experienced it on both front shocks which are now KYB. Good luck---
Old Jan 25, 2019 | 08:51 PM
Nescu777's Avatar
2007 RL struts
The problem started with a weird noise on the right side,I feel like it's not always there it's more like a clunky noise
i went to the mechanic and he checked the whole thing and he said that it might be the strut mount broken and that could make the noise
the thing is that if I change just the strut mount and btw for that should I buy original Acura,the mechanic will charge for the whole job like changing the struts
so that's why I was thinking to change the whole thing, my car now is just a little shy of 100k btw
Old Jan 26, 2019 | 12:03 PM
TonyCD's Avatar
FWIW, I've liked my KYB's. Sufficient control and a much less punishing ride than I experienced with A-Spec.
rlx015's Avatar
+1 for KYB - I have installed them on my RL.
Regarding the clunk noise, I am more inclined to think it is an engine mount and not struts. I had this done on my RL and because of the clunking noise, I replaced all motor mounts/engine mounts (total three).
Struts and shocks I replaced because the sign they were bad was all four tires cupping mechanic noticed and told me about it.
I think OEM engine mounts (extremely recommending to go with OEM mounts) are about $500 parts (for all three)
MOUNTING ASSY., RR. ENGINE 50810-SJA-E01 167.76
RUBBER ASSY., ENGINE SIDE MOUNTING 50820-SJA-305 148.73
RUBBER ASSY., FR. ENGINE MOUNTING (AT) 50830-SJA-305 164.4
Shipping was $25 - all together shipped around $505...
www.acuraoemparts.com
Old Jan 26, 2019 | 02:30 PM
TonyCD's Avatar
Normally the tell for an engine mount would be, do you get an unusual clunk when you shift between drive and reverse?
That said, as you've probably gathered if you've scanned the forums, these cars are prone to lunching the mounts at this age. They're made of fluid-filled rubber, and rubber rots.
As an aside, if that's the issue, you can go aftermarket for greater durability, but then you compromise the superior NVH of this luxury-oriented car. That sacrifice wasn't worth it to me, so I replaced with OEM.
Old Jan 26, 2019 | 10:37 PM
Nescu777's Avatar
2007 RL struts
I did the timing belt on it in September, honestly I don't really remember if I had the noise or not back then, and I'm saying that because the mechanic had to take one mount off to do the job, and from my understanding if not tightened at the right torque the thing can be damaged easily
I did look for some aftermarket engine mounts and I've found that innovative mounts make some that would fit the model
now I don't really know exactly how they would really feel, or if the quality is really good
if you guys have any idea feel free to share some thoughts on them
Old Jan 28, 2019 | 02:57 PM
rlx015's Avatar
In my case clunk was happening when I was going over very slight humps or potholes, etc. - when there is a surface difference and car goes over it, it would clunk - regardless of the transmission and what gear I was in. Mount is unlikely to be the cause of the noise if you change gears from P to D or Reverse... simply because engine and car are not moving - not sure if I understood the earlier point though.
I still vote against the "aftermarket" engine mounts.
Old Jan 29, 2019 | 08:56 PM
Acura05rl's Avatar
I use to use KYB on me 95 Legend GS and they sucked big time. I had to replace them frequently. It’s hard to believe that their quality improved for this RL. Just saying....
Old Jan 29, 2019 | 11:42 PM
stevieray's Avatar
KYBs for the Legend did suck, the shock of choice is/was Eibachs. I had a '92 L Sedan and a '95 LS Coupe. The RL shock is a totally different animal, OEM ride and $85/per vs $356 for OEM that is known to have a defect. Pretty easy choice when I can buy 4 KYBs for what one OEM cost.
jefflikesbagels
4G TL Problems & Fixes
Jul 6, 2019 09:26 PM
macfwt
Jun 16, 2019 05:46 PM
Verk26
New Member Introductions
Jan 25, 2019 03:02 PM
Saudade
Jan 20, 2019 11:39 PM
