2005 RL power steering pump pulkey
I replaced my serpentine belt and now my power steering pulley sounds aweful...making like a ticking noise...the pump isn't making any noise and steering is fine. But how do you get that pulley off to replace it? It doesn't have a nut like I've seen on other acura's...thanks
Nersh7 (12-08-2014)
Service manual is here: https://acurazine.com/forums/second-.../#post11094005
I Drive Like A Dick 8≈
the funny thing; I had a 14mm wrench in hand and could have easily switched to the wrench to finish the job.
i went to town with the ratchet and was like oh shit. its stuck.![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
then, i made it worse by continuing to loosen the bolt making the ratchet even more stuck!
i took a vice grip to the socket and tightened the bolt.
which in turn, made the ratchet loose enough to where I could take it out.
then finished the job with a wrench.![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
Noob mistakes! but better believe I learned not to do it again.
mike from annapolis
05-07-2017 08:21 PM
asahrts
09-04-2015 05:55 PM
