2005 RL Not Starting
Hey guys, I went outside last night to move my car for a friend and it wouldnt start. I'm pissed because I just bought a battery for the car earlier in the day because the car wouldnt start every morning when I would come out in below freezing weather. I thought it was just the battery but I guess not. I dont think its the alternator because with the battery I had the day before I was able to jump it and let the car run for a long time to heat up and the I drove it for a few miles to charge the battery. As soon as I got home and turned off the car I tried to start it to see if the battery charged. It wouldnt start within ten seconds of me turning the engine off. So I bought the new battery and came home around 5pm after I put it in myself. Even when I first put it in it still had the same weak turn over but it started after a few turns. Now it wont turn over at all but all the electronics come on and the defrost will even blow. However there is a whining noise when the the fan comes on so I turned it off. That never happened until the day before I bought the new battery. I can hear a click but I cant tell if its from the dash lighting up. I think its something to do with the starter. I had the 05 TSX and the starter went but atleast I could pop the clutch to start that so I knew it was the starter. Its at 119K but I replaced the engine at 109k so the engine has 12k miles on it right now. Is there anything else to check before I spend too much money to have it fixed? Maybe the recall on the fuel pump? Or a fuse I could check? When I last went to start it cranked a few times then stopped. Then cranked 2 times before stopping. Then a half crank, now nothing.
Stay Out Of the Left Lane
My guess is the starter. You said you replaced the engine (10K?) ago, but was the starter replaced as well or did that carry over? Try giving the starter a couple of good whacks with a hammer/mallet/bar and try starting again.
After replacing the battery, I would have expected it to fire right up and not have "the same weak turnover." That is unless you were unlucky enough to have purchased a bad battery. Does the dashboard light up? Headlights work? Radio?
But getting back to the current problem, I tried give the starter a few good taps but it didnt make any difference. Still no Luck. I called the only Acura dealership around and they quoted me $630 for parts and labor on a new starter. est.3 hours of labor. It looks like I'll be buying one online and finding someone to install it for me because thats way too much. If anyone has any other things I could try while I wait for the starter to arrive I'd love to know
do you have a multimeter? If battery is good, and alternator is putting out 14.7 volts or so, then the next thing I would do is a voltage drop test on the cables. Will tell you if starter is not getting full juice due to bad cables or connections. If they check out, then you can throw a starter at it, or at least yank it and have it bench checked...
Very long shot but you might want to try starting with the gear selector in neutral as opposed to park. Sometimes the safety interlock switch can fail, but I don't think this is your issue.
Can you jump it? That would tell you if it's your starter or charging system. I'm betting bad alternator killed both batteries.
OR, your battery cables on the other end from the battery aren't making a connection. Similar to Heavy's suggestion, but away from the battery.
Hey guys, I finally got everything fixed. It turns out that the starter was fried somehow. I took it out in about 15 minutes to get it out and I took it to Autozone to have it tested. The starter failed to even function. I took it to a rebuild place that said it was completely fried and several parts would have to be replaced so I just opted for a new one from Autozone. I put it in and the car started just fine. I'm glad the Starter in the RL is so easy to get to because I've never done any car work besides changing the wheels from all seasons to snows. Unfortunately the battery that I bought before I knew it was the starter isn't a flat top so I had to go to Pep Boys to get post shims to make the terminals fit
handsom-hustla
Nov 13, 2015 05:04 PM
cak165
1G TSX Problems & Fixes
Sep 16, 2015 08:17 PM
