2005 RL driver window won't go down
My 05 acura rl my driver side window clicks when I push down on the switch. I replaced the switch, regulator, and control module and the same thing. The control module box clicks. Someone please help
2005 Acura RL Window Reset Procedure
Hi Dennis, I have been dealing with the same issue, the drivers control works for all other three windows but not the drivers window even after replacing the power window motor/mechanism. I bench tested the replacement motor and I confirmed it worked. Did you ever resolve this issue?
z'stl
08-26-2013 12:17 PM
