1/4 mile times for my 05 RL on 19's NA before the SC
Old 07-19-2016, 08:36 AM
JDMCRX's Avatar
Took the car to the track two weeks ago forgot to post.
05 RL
PCD
J Pipe with high flow cat
68mm throttle body
3.5" intake with velocity stack
XL8R Crank pulley
Im on 19's and H&R springs
I tried a few different combos of launching.
14.9 at 96mph with a 1.8 60ft was my second and best run I was seeing 140deg f Intake Temps in the stage lane which was hurting the car. Reved it to 2100 and launched and shifted with the paddles.
Im going to move the IAT sensor into the intake pipe this week and try again before I install the SC
Old 07-19-2016, 10:04 AM
oo7spy's Avatar
Received 7,247 Likes on 4,858 Posts
Old 07-19-2016, 12:09 PM
cib16waker's Avatar
05 RL
PCD
68mm throttle body
XL8R Crank pulley
I have been searching for a Supercharger for a month now. What unit are you using and where did you find it? Do you have a link to the website or how are you building this?
Old 07-19-2016, 03:23 PM
JDMCRX's Avatar
I am doing s comptech SC for the 04-08 TL
AEM FIC with custom jumper harness built by myself and I will tune the car .
I've been told that M62 blower on the j35 yields 2.5-3psi.
Last RL stock made 272whp at 3psi.
I'm hoping with my mods to hit the 300whp mark !
Old 07-19-2016, 03:27 PM
cib16waker's Avatar
You should go to the website www.change2e85.com and purchase the kit for your car. It'll give you probably 40 to 50 wheel horsepower if your boosted. Anyways what is the unit and kit you're using for your car to supercharge it?
Old 07-19-2016, 03:46 PM
oo7spy's Avatar
He already said that. Comptech SC for '04-'08 TL.
Old 07-19-2016, 03:48 PM
cib16waker's Avatar
So he just bought the kit for the TL and put it on the RL? What kind of fabrication is involved in that? Please put up pictures of the install before during and after period I'm putting my E85 kit on when I do my supercharger because I want to have a base Dyno than a 85 Dyno and then a supercharged Dyno with and without the 85
Old 07-19-2016, 04:18 PM
teh CL's Avatar
Son of a...
Old 07-19-2016, 04:28 PM
Shoxrider's Avatar
cant wait to do something like this someday!
Old 07-19-2016, 04:30 PM
cib16waker's Avatar
Yeah it's going to be awesome. Once he responds and tells me how he's doing it I'm going to do it also and throw the TL supercharger on the RL. I'll send all kinds of pictures and stuff. Dino before and after with the stock gas versus the 85 upgrade. Then I'll Deuce 93 octane supercharged and E85 supercharged. I just need to know if the TL supercharger is a direct bolt-on for the RL or what has to be done LOL. I've got my finger on the comp Tech order form right now haha
Old 07-19-2016, 07:13 PM
JDMCRX's Avatar
The 04-08 kit will fit.
Same engine so the cam cap will line up and the belts are exactly the same. Only the .3L of displacment and extra flow of the heads lowers the Boost pressure on the stock pulley.
I get the kit thursday and will drop the motor out of the car and slap it on and show you guys what has to be modified.
Im not sure if we can run E85 in our cars due to there being possibly some rubber in our fuel system ? Not sure but im just running it on 91-93 thats all we have around here.
The max boost we will be able to get is 6psi due to the blower speeds of 14,000rpm. Ill see how the IAT are , im going to do meth but ill be happy at 300whp.
Our trannies should hold the power as in between shifts the ECU closes the Throttle while the tranny shifts gears.
Here is a silver RL in 2009 that was done and it made 272whp at 2.5-3psi all stock and zero tunning, im guessing the stock ecu has a small boost table in the maps ??
Old 07-19-2016, 07:18 PM
cib16waker's Avatar
That's awesome I'm really excited to see it. I never knew anyone else did it. We can run E85 in our cars I already talked with an Acura Specialist as well as the company that sells the kit. You just have to check the polarity of your injectors and they lined right up and everything works fine and you can still use it just like flex fuel
Old 07-19-2016, 08:25 PM
projektvertx's Avatar
It's about to get good.
Old 07-19-2016, 10:39 PM
cib16waker's Avatar
Yeah I'm really excited. I've been waiting to do this for a long time. I just love the supercharger whine. I'm going to need like a complete parts list and maybe a video if you can do it, of every custom modification you have to do to install it compared to an tl
Old 07-19-2016, 11:14 PM
JDMCRX's Avatar
I'll take lots of pics with the engine out of the car so you guys can see what has to be modified !
I will also dyno the car on a mustang dyno before and after I hope !!
Old 07-20-2016, 09:56 AM
oo7spy's Avatar
No AWD DYNO? For as much research as you've done, I'm sure you know the SH-AWD doesn't like DYNOs and your numbers will likely be lower than what you get on pavement. The SC car you quoted had the driveshaft disconnected and was FWD DYNO'ed for accurate increase measurements.
Old 07-20-2016, 10:10 AM
JDMCRX's Avatar
You can dyno the SH AWD on a mustang MD-AWD-500 mechanically connected rollers. Disconnecting the Drive shaft is ghetto and does not provide accurate readings.
Old 07-20-2016, 10:12 AM
cib16waker's Avatar
I was just going to suggest that lol, us Acura boys aren't Ghetto haha, no dosconnecting that perfect SH-AWD system, it's just so beautiful ... I wonder if you can get an ECU where you can alter the power delivery ( like a subaru STI has )
Old 07-20-2016, 11:11 AM
oo7spy's Avatar
I can't imagine how it is ghetto. It's not like you leave it like that. It reduces the variables that could impact the results. How is that ghetto?
Old 07-20-2016, 11:47 AM
teh CL's Avatar
Whenever your done, I'm making a cruise out there..
Old 07-20-2016, 12:28 PM
cib16waker's Avatar
I'm in Florida and I'll have mine done after him, I didn't know the same unit will fit...I'm so excited you guys have no idea
Old 07-20-2016, 12:43 PM
3.5 psi
gnuts's Avatar
The comptech kit only hides boost from the computer. Along with the rising rate fuel pressure regulator, the stock ECU can handle it. That's what I'm running, stock pulley I see 3.5psi.
I've been monitoring things using the torque app and I see IATs of 150*F. Coolant is also elevated and I think it's from radiant heat. I'm going to be grabbing some heat shielding and monitoring the differences.
Old 07-20-2016, 01:01 PM
JDMCRX's Avatar
You have the comptech on a RL with the 3.5?
Stretch203 (07-20-2016)
Old 07-20-2016, 01:23 PM
cib16waker's Avatar
That's what I was wondering also. It seems that he has it done already. If that's the case I would love to see some pictures and hear about the install immediately
Old 07-20-2016, 01:24 PM
Received 16,266 Likes on 11,974 Posts
you guise do know the RL shares its engine with the rest of the Acura line up????
gnuts has a CL....
thus why the other poster said a TL's CT supercharger can fit the RL....because every one of them shares the engine.
Old 07-20-2016, 01:26 PM
teh CL's Avatar
Old 07-20-2016, 01:29 PM
I always take for granted that we know gnuts....and the two new gentlemen dont.
Old 07-20-2016, 01:42 PM
oo7spy's Avatar
JDMCRX is not new. He has 7 years on you.
Old 07-20-2016, 08:02 PM
3.5 psi
gnuts's Avatar
Like they said above I have a CL, I just sharing info since all comptech kits are basically the same.
Why do you have to pull the engine? I would suggest a battery relocation to the trunk while you do this.
oo7spy (07-20-2016)
Old 07-20-2016, 09:11 PM
oo7spy's Avatar
Do you have a link to a documented build?
Old 07-20-2016, 10:43 PM
JDMCRX's Avatar
Oh ok thought so you have the 3.2.
I'm dropping the motor cause I'm doing xl8r engine mounts and I have a hoist so easy to drop the motor mount it all up then drop car on the engine
teh CL (07-21-2016)
Old 07-21-2016, 07:56 AM
Rawr.
Marcelechka's Avatar
You can definitely boost well past the efficiency of the blower; but, with the added heat, just need to keep the IAT in check to utilize the added charged air....beit meth, IC, watercooler, etc.
Here is a silver RL in 2009 that was done and it made 272whp at 2.5-3psi all stock and zero tunning, im guessing the stock ecu has a small boost table in the maps??
Stock ecu for any J series motor goes into limp mode as soon as it detects boost... it retards timing to compensate what ever positive pressure it sees. Either use the CT ESM to hide boost; or a piggyback unit to manipulate the stock ECU; or a standalone unit.
I can assure you, there are no hidden maps to be unlocked with the stock ecu.
teh CL (07-21-2016)
Old 07-21-2016, 12:46 PM
JDMCRX's Avatar
Old 07-21-2016, 02:02 PM
3.5 psi
gnuts's Avatar
What track did you go to? I'd love to go but none of my friends are into cars.
Old 07-21-2016, 02:06 PM
how is that even possible?!
"hey bro, cool car!"
"thanks man"
"bro, we should hang out. because I like your car and not you."
"dude, lets go to the track!"
or you could always play pokemon. I'm sure like minded people are playing pokemon too! lol
of course, im just being dumb and playing out all these scenarios....
Old 07-21-2016, 04:37 PM
oo7spy's Avatar
I'm surprised you beat the VW off the line but lost it at the end. I figured the RL would typically behave the other way around.
Old 07-21-2016, 09:36 PM
3.5 psi
gnuts's Avatar
Teh CL has broken axles so he can't go
Old 07-22-2016, 07:39 AM
teh CL's Avatar
Teh CL has broken axle so he can't go
Fixed.
Old 07-22-2016, 10:35 AM
JDMCRX's Avatar
I was launching the car at 2100rpm . I was playing with the launch but the IAT were supper high and if you hold the rpm to high the ecu will shut you down and you have to wait to try it again . I was getting 1.8 60ft .
Here is what I picked up yesterday
Old 07-22-2016, 10:52 AM
teh CL's Avatar
Jealousy is at an all time high..
Get a good deal on it?
oh and
