07-08 RL Differences?
Old Feb 25, 2010 | 10:43 AM
Indy04TL's Avatar
Thinking of buying a 07-08 RL. What are the differences between the two model years? Transmission, engine, etc. Thanks!!
Old Feb 25, 2010 | 01:58 PM
Chas2's Avatar
Try this link. It is generally accurate.
http://en.wikipedia.org/wiki/Acura_RL
For more detailed analysis, you need to go to the Acura Media Newsroom
Using the archived year entries, you need to compare the different technical releases of each year.
http://www.hondanews.com/categories/793
Old Feb 25, 2010 | 03:49 PM
Indy04TL's Avatar
Thanks! That answered my question.
Old Feb 26, 2010 | 08:35 PM
SSjTrunks112O's Avatar
Aside from the different color names & slightly higher MSRP, the two years look to be pretty much identical right?
Old Feb 27, 2010 | 03:34 PM
Chas2's Avatar
Yes that is correct. There may be minor differences such as the use of real wood vs fake wood. At some point, the real wood was only available in the ACC/CMBS models, whereas in 2005, they all had real wood, at least on the front dash. I think the doors were always plastic wood.
Old Feb 27, 2010 | 07:35 PM
Yep all trims & model years had plastic wood doors. I always thought that all '05 & '06 dashes were real wood & '07-'08 Tech's & ACC/CMBS's were real wood as well. As for '09's & up, only the ACC/CMBS trims had the real wood dash.
Correct me if I am wrong though.
Old Feb 28, 2010 | 10:32 AM
Chas2's Avatar
Something along those lines. You may be able to trace it through the Tech releases for each year, but I recall it may also have been only traceable by comparing the acura.com websites for each year, or the brochures, neither of which are readily available. Not something I want to do now....
Recipe7
3G RLX (2013+)
45
Dec 7, 2015 06:43 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
joflewbyu2
Oct 8, 2015 11:16 AM
thegipper
Sep 28, 2015 01:01 PM
eastcoastguy
Sep 23, 2015 06:29 AM
